Viewing Server Asset Fingerprints
HSS can collect server asset fingerprints, including information about ports, processes, web applications, web services, web frameworks, and auto-started items. You can centrally check server asset information and detect risky assets in a timely manner based on the server fingerprints. HSS does not touch your assets. You need to manually eliminate the risks.
This section describes how to view the collected server asset fingerprints on the console. For more information, see Collecting Server Asset Fingerprints.
The server fingerprint function is available in HSS enterprise, premium, WTP, and container editions. For details about how to purchase and upgrade HSS, see Purchasing an HSS Quota and Upgrading a Protection Quota.
Viewing Asset Information of All Servers
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project. - Choose .
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- View the server fingerprints.
Figure 1 Viewing server fingerprints
- Click a fingerprint type in the list to view the asset information.
- (Optional) Remove risky assets.
If you find unsafe assets after counting, remove them in a timely manner.
If you receive port alarms, you can set Dangerous Port to Yes in the search box of the Open Ports area to filter dangerous ports. You are advised to handle unsafe ports as follows:
- If HSS detects open high-risk ports or unused ports, check whether they are really used by your services. If they are not, disable them. For dangerous ports, you are advised to further check their program files, and delete or isolate their source files if necessary.
- If a detected high-risk port is actually a normal port used for services, you can ignore it. Ignored alarms will neither be recorded as unsafe items and nor trigger alarms.
For more information, see High-risk port list.
Viewing the Asset Information of a Single Server
- Click
in the upper left corner and select a region or project. - In the navigation pane, choose . Click the Servers tab.
- Click the name of the target server. On the server details page that is displayed, choose .
Figure 2 Viewing asset fingerprints of a single server
High-risk port list
Table 1 lists the high-risk ports are identified by the asset fingerprint function of HSS. If a high-risk port is enabled in your asset, check whether they are really used by your services.
Port |
Description |
Protocol |
31 |
Trojan horses Master Paradise and Hackers Paradise |
TCP and UDP |
456 |
Trojan horses HACKERSPARADISE |
TCP and UDP |
555 |
Trojan horses PhAse1.0 Stealth Spy and IniKiller |
TCP and UDP |
666 |
Trojan horses Attack FTP and Satanz Backdoor |
TCP and UDP |
1001 |
Trojan horses Silencer and WebEx |
TCP and UDP |
1011 |
Doly Trojan |
TCP and UDP |
1025 |
Trojan netspy |
TCP and UDP |
1033 |
Trojan netspy |
TCP and UDP |
1070 |
Trojan horses Streaming Audio Trojan, Psyber Stream Server, and Voice |
TCP and UDP |
1234 |
Trojan horses SubSeven2.0 and Ultors Trojan |
TCP and UDP |
1243 |
Trojan SubSeven 1.0/1.9 |
TCP and UDP |
1245 |
Trojan Voodoo |
TCP and UDP |
1270 |
MOM-Encrypted Microsoft Operations Manager (MOM) |
TCP |
1492 |
Trojan FTP99CMP |
TCP and UDP |
1600 |
Trojan Shivka-Burka |
TCP and UDP |
1807 |
Trojan SpySender |
TCP and UDP |
1981 |
Trojan ShockRave |
TCP and UDP |
1999 |
Trojan BackDoor |
TCP and UDP |
2000 |
Trojans GirlFriend 1.3 and Millenium 1.0 |
TCP and UDP |
2001 |
Trojan Millenium 1.0 and Trojan Cow |
TCP and UDP |
2023 |
Trojan Pass Ripper |
TCP and UDP |
2115 |
Trojan Bugs |
TCP and UDP |
2140 |
Trojan Deep Throat 1.0/3.0 |
TCP and UDP |
3150 |
TCP and UDP |
6711 |
Trojan SubSeven1.0/1.9 |
TCP and UDP |
6776 |
Trojan horses SubSeven2.0 and Ultors Trojan and SubSeven1.0/1.9 |
TCP and UDP |
