Help Center/ Host Security Service/ User Guide/ Asset Management/ Container Management/ Viewing the Container Node Protection Status
Updated on 2025-09-29 GMT+08:00
The Container Nodes page displays the protection, node, and agent status of containers, helping you learn the node security status in real time.
  • Only Linux servers are supported.
  • Servers that are not protected by HSS enterprise, premium, WTP, or container editions cannot perform container-related operations.
  1. Log in to the HSS console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane, choose Asset Management > Containers & Quota. Click the Container Nodes tab.
  4. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  5. View the node protection status. For details, see Table 1.
    Table 1 Parameter description
    Server Information
    Server information, including the server name and IP address. You can hover your cursor over a server name to view the server details, including the server ID, OS, system name, and system version.
    Protection Status
    Protection status of a node. The options are as follows:
    • Unprotected: HSS is disabled for the server. After the agent is installed, click Enable in the Operation column to enable protection.
    • Enabled: The server is fully protected by HSS.
    • Protection interrupted: The server is shut down, the agent is offline, or the agent is uninstalled.
    Server Status
    • Running
    • Unavailable
    • Normal
    Agent Status
    You can select a status to view the server.
    • Online: The agent is running properly.
    • Offline: The communication between the agent and the HSS server is abnormal, and HSS cannot protect your servers.
      For an IDC server, its information will be automatically deleted from the node management page after its agent goes offline for 30 days.
    • Not installed: The agent has not been installed or successfully started.
