Help Center/ Host Security Service/ User Guide/ Enterprise Project Management/ Managing Projects and Enterprise Projects
Updated on 2025-04-24 GMT+08:00
Selections are available only if you have enabled the enterprise project function, or your account is an enterprise account. To enable this function, contact your customer manager. An enterprise project provides a cloud resource management mode, in which cloud resources and members are centrally managed by project.
Creating a Project and Assigning Permissions
  • Creating a project
    Log in to the management console, click the username in the upper right corner, and select Identity and Access Management. In the navigation pane on the left, choose Projects. In the right pane, click Create Project. On the displayed Create Project page, select a region and enter a project name.
  • Granting permissions
    You can assign permissions (of resources and operations) to user groups to associate projects with user groups. You can add users to a user group to control which projects they can access and what resources they can perform operations on. To do so, perform the following operations:
    1. On the User Groups page of the IAM console, locate the target user group and click Authorize in the Operation column. Grant permissions to the project.
      For details, see Granting a User Group Permissions for a Project in the IAM help.
    2. On the Users page, click a username to go to the details page. In the User Groups area, add a user group for the user.
Creating an Enterprise Project and Assigning Permissions
  • Creating an enterprise project
    On the management console, click Enterprise in the upper right corner. The Project Management page is displayed. In the upper right corner of the Project Management page, click Create Enterprise Project and create a project as prompted.
    Enterprise is available on the management console only if you have enabled the enterprise project, or you have an enterprise account. To enable this function, contact customer service.
    You can add a user group to an enterprise project and configure a policy to associate the enterprise project with the user group. You can add users to a user group to control which projects they can access and what resources they can perform operations on. To do so, perform the following operations:
    1. On the Project Management page, click the name of an enterprise project to go to its details page.
    2. On the Permissions tab, click Authorize User Group to go to the User Groups page on the IAM console. Associate the enterprise project with a user group and assign permissions to the group.
      For details, see Creating a User Group and Assigning Permissions in the IAM help.
  • Associating HSS with enterprise projects
    You can use enterprise projects to manage cloud resources.
    • Select an enterprise project when purchasing HSS.
      On the page for buying HSS, select an enterprise project from the Enterprise Project drop-down list.
    • Adding resources
      On the Enterprise Project Management page, you can add existing ECSs/BMSs to an enterprise project.
      Value default indicates the default enterprise project. Resources that are not allocated to any enterprise projects under your account are displayed in the default enterprise project.
    For more information, see Creating an Enterprise Project.
