Updated on 2026-09-07 GMT+08:00
Unbinding a Protection Quota
You can unbind quotas from servers that no longer need to be protected. Exercise caution when performing this operation, because unprotected servers are exposed to security risks.
After unbinding a quota, you can bind it to another server or unsubscribe from it to reduce cost.
If you enable HSS when purchasing a server (such as an ECS or FlexusX), you can bind the quota to another server only one hour after unbinding it.
Unbinding a Quota from a Server
  1. Log in to the HSS console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, choose Asset Management > Servers & Quota. On the displayed page, click the Quotas tab. On the Quotas page, click the different option buttons to filter and view the target quota list.
  4. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  5. On the Quotas page, click Unbind in the Operation column of a quota.
    To unbind quotas in batches, select the servers they bind to, and click Batch Unbind above the quota list.
  6. In the confirmation dialog box, click OK.
Unbinding a Container Quota
  3. In the navigation pane on the left, choose Asset Management > Containers & Quota. On the displayed page, click the Quotas tab. On the Quotas page, click the different option buttons to filter and view the target quota list.
