Updated on 2025-08-26 GMT+08:00
Viewing Protection Quotas
You can check, renew, and unsubscribe from your quota in the server list.
Only the quota purchased in the selected region is displayed. If your quota is not found, ensure you have switched to the correct region and search again.
Viewing Server Quotas
  2. In the upper left corner of the page, select a region, click , and choose Security & Compliance > Host Security Service.
  3. In the navigation pane on the left, choose Asset Management > Servers & Quota. On the displayed page, click the Quotas tab. On the Quotas page, click the different option buttons to filter and view the target quota list.
  4. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  5. On the Quotas tab page, view HSS quotas. Table 1 lists the related parameters.
    Table 1 Parameter description
    Quota ID
    Unique ID of a quota. Click the quota ID to go to the basic information page. On this page, you can view the quota creation time, expiration policy, and last transaction order. You can also add tags to the quota on this page.
    Edition
    • Basic
    • Professional Edition
    • Enterprise
    • Premium
    • Web Tamper Protection (WTP)
    Usage Status
    • In use: The quota is being used for a server. The name of the server is displayed below the status.
    • Idle: The quota is not in use.
    Quota Status
    • Normal: The quota has not expired and can be used properly.
    • Expired: The quota has expired. During this period, you can still use the quota.
    • Frozen: During the frozen period, the quota is unbound from the server and the server is no longer protected. After the frozen period expires, the quota is permanently deleted. If the quota expires and enters the frozen period, you can renew the quota in time, and the quota will be automatically bound to the original server (unless that server has been bound to another quota). If the quota is frozen due to public security reasons or violations, only after it is unbound by public security or violation management personnel, can it be automatically bound to the original server (unless that server has been bound to another quota).
    Billing Mode
    • Yearly/Monthly
    • Pay-per-use
    Enterprise Project Name
    Name of the enterprise project to which the target quota belongs
    Tag
    Resource category tag.
    • Binding quota to a server
      Alternatively, choose Asset Management > Servers & Quota from the left navigation pane, and click the Quotas tab. In the quota list displayed, click Bind Server in the Operation column to bind a quota to a server. HSS will automatically protect the server.
      A quota can be bound to a server to protect it, on condition that the agent on the server is online.
    • Unbind
      On the Quotas tab of the Servers & Quota page, click Unbind in the Operation column of a quota. HSS will no longer protect the server and the quota status will change to Idle.
    • Export the quota list.
      Click in the upper right corner of the quota list to export the quota information on the current page.
Viewing Container Quotas
  3. In the navigation pane on the left, choose Asset Management > Containers & Quota. On the displayed page, click the Protection Quotas tab.
  4. On the Protection Quotas tab page, view HSS protection quotas. Table 2 lists the related parameters.
    Table 2 Parameter description
    Quota ID
    Quota ID Click the quota ID to go to the basic information page. On this page, you can view the quota creation time, expiration policy, and last transaction order. You can also add tags to the quota on this page.
    Quota Version
    Enterprise edition
    Quota Status
    • Normal: The quota is normal.
    • Frozen: During the frozen period, the quota is unbound from the container node and the container node is no longer protected. If you renew the quota in time, the quota will be automatically bound to the container after the renewal is complete. After the frozen period expires, the quota will be permanently deleted.
    Usage Status
    Billing Mode
    • Yearly/Monthly
    • Pay-per-use
    Tag
