Updated on 2025-07-11 GMT+08:00
Configuring a RocketMQ Client
Suggestions on configuring a RocketMQ client.
Java Client Version
5.1.4 and later are recommended.
Unique ClientId
By default, ClientId combines the process ID, local IP address, and instance name. When two consumers in a consumer group are started in a process, their ClientIds are the same. As a result, some queues are repeatedly consumed and others cannot be consumed.
Recommended Setting
ClientId is generated with clientIP of a consumer. If different consumers share a clientIP at the same IP address, ClientId will be the same. You are advised to add the following code to manually set instanceName.
producer.setInstanceName(String.valueOf(System.nanoTime()))
Producer Exception Detection
Available in Java client 5.1.4 and later.
Enable exception detection on a client. When accessing a broker times out, the client can quickly switch to another broker for message production.
producer.setSendLatencyFaultEnable(true)
