Enabling RocketMQ ACL
RocketMQ instances support precise identification of producers and consumers through ACL (Access Control List)-based permission management. When ACL is enabled, message production and consumption require authentication.
Notes and Constraints
- ACL can be configured only for instances purchased after August 21, 2021.
- Enabling ACL will disconnect clients without authentication configuration.
Prerequisite
A RocketMQ instance has been purchased.
- Log in to the console.
- Click
in the upper left corner to select a region.
DMS for RocketMQ instances in different regions cannot communicate with each other over an intranet. Select a nearest location for low latency and fast access.
- Click
and choose Middleware > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
- Click a RocketMQ instance to go to the instance details page.
- In the Connection area, click
next to ACL to enable ACL.
When ACL is enabled, Users is displayed in the navigation pane. You can configure ACL users by referring to Configuring RocketMQ ACL Users.
Related Documents
- To configure ACL by calling an API, see Modifying Instance Information.
- To configure ACL users when ACL is enabled, see Configuring RocketMQ ACL Users.
