Configuring SSL of a RocketMQ Instance
You can access a RocketMQ instance in plaintext or ciphertext. This section describes how to change the access mode on the console.
RocketMQ instances support the following access modes:
- SSL: Ciphertext access with high security, but lower performance.
 - PLAINTEXT: Plaintext access with high performance, but lower security.
 - PERMISSIVE: Both ciphertext and plaintext access, depending on the client.
Operation Impact
Table 1 lists the impact of changing the access mode.
PERMISSIVE is unavailable for some existing RocketMQ instances. For details, see the console.
         Server Access Mode Change  |
         Impact  |
         PLAINTEXT > SSL  |
         SSL > PLAINTEXT  |
         PLAINTEXT > PERMISSIVE  |
         Instances will not be restarted and services will not be interrupted.  |
         SSL > PERMISSIVE  |
         PERMISSIVE > PLAINTEXT  |
         PERMISSIVE > SSL  |
Prerequisite
You can change the access mode of a RocketMQ instance only when the instance is in the Running state.
- Log in to the console.
 - Click
 in the upper left corner to select a region.
     DMS for RocketMQ instances in different regions cannot communicate with each other over an intranet. Select a nearest location for low latency and fast access.
 - Click
 and choose Middleware > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ. - Click a RocketMQ instance name to go to the instance details page.
 - In the Connection area, specify SSL option. The Confirm dialog box is displayed.
 - Click OK. The Background Tasks page is displayed.
If the SSL change task is in the Successful state, the instance access mode is changed successfully.
Related Documents
- To set SSL to PLAINTEXT or PERMISSIVE and access RocketMQ on a client for message production and consumption, see Accessing RocketMQ on a Client (Without SSL).
 - To set SSL to SSL or PERMISSIVE and access RocketMQ on a client for message production and consumption, see Accessing RocketMQ on a Client (With SSL).
