Migrating RabbitMQ Metadata to a RocketMQ Instance
On the console, you can migrate RabbitMQ metadata to your DMS RocketMQ instance.
- A RocketMQ instance has been purchased.
- RabbitMQ plug-ins have been enabled.
- A RabbitMQ 3.7.17/3.8.35 instance has been purchased.
Step 1: Obtain RabbitMQ Metadata
- Enter http://IP address of your RabbitMQ:15672/ in the address box of the browser to access the open-source RabbitMQ console.
- On the login page, enter the username and password, and click Login.
The default username and password are the ones configured in RabbitMQ instance purchase.
- On the Overview tab page, click Download broker definitions to export the metadata.
Figure 1 Exporting metadata
Step 2: Migrate Metadata on the Console
- Log in to the console.
- Click
in the upper left corner to select a region.
DMS for RocketMQ instances in different regions cannot communicate with each other over an intranet. Select a nearest location for low latency and fast access.
- Click
and choose Middleware > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
- Click a RocketMQ instance to go to the instance details page.
- In the navigation pane, choose Cloud Migration > Metadata Migration.
- Click Create Migration Task.
- Configure the migration task by referring to Table 1.
Table 1 Migration task parameters Parameter
Task Type
Select From RabbitMQ to RocketMQ.
Task Name
Unique name of the migration task.
A task name must meet the following requirements:- Contains 4 to 64 characters.
- Contains only letters, digits, hyphens (-), and underscores (_), and must start with a letter.
Overwrite
- If this option is enabled, configurations in the metadata file with the same name as the uploaded file will be modified.
Assume that Topic01 on the source instance has three read queues, and Topic01 on the DMS instance has two read queues. If Overwrite is enabled, Topic01 on the DMS instance will have three read queues after migration.
- If this option is disabled, migration of the metadata file with the same name as the uploaded file will fail.
Assume that the source instance has Topic01 and Topic02, and the DMS instance has Topic01 and Topic03. If Overwrite is disabled, migration of the source Topic01 will fail.
Metadata
Upload the RabbitMQ metadata.
- Click OK.
After the migration is complete, view Task Status in the migration task list.
- If Task Status is Complete, all metadata has been successfully migrated.
Produce and consume messages by referring to Accessing RocketMQ on a Client (Without SSL) or Accessing RocketMQ on a Client (With SSL) to ensure that metadata is available.
- If Task Status is Failed, some or all metadata fails to be migrated.
Click the migration task name to go to the migration task details page. In the Migration Result area, view the name of the topic or consumer group that fails to be migrated, the failure cause, and the solution.
Related Document
To create a metadata migration task by calling an API, see Creating a Metadata Migration Task.
