Updated on 2024-09-20 GMT+08:00
Viewing RocketMQ Monitoring Metrics
Cloud Eye monitors RocketMQ instance metrics in real time. You can view these metrics on the console.
A RocketMQ instance has been purchased.
Viewing RocketMQ Metrics
  1. Log in to the console.
  2. Click in the upper left corner to select a region.
    Select the region where your RocketMQ instance is located.
  3. Click and choose Middleware > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
  4. Click a RocketMQ instance name to go to the instance details page.
  5. Choose Monitoring And Alarm > Monitoring in the navigation pane.
  6. View monitoring data by the instance, brokers, topics, consumer groups, and dead letter queues.
  7. (Optional) Click View details on the By Instance, By Broker, By Topic, By Consumer Group, or By Dead Letter Queue tab page to go to the Cloud Eye console.
    On the instance list page, you can also click View Metric in the row containing the desired instance to go to the Cloud Eye console.
    On the Cloud Eye console, you can select metrics and rearrange their order.
    For example, if you only need to view the Created Messages and Retrieved Messages metrics on the By Broker tab page, do as follows:
    1. On the By Broker tab page, click Select Metric.
    2. Select Created Messages and Retrieved Messages, and click OK.
    3. Drag and drop the selected metrics to desired locations to rearrange the order.
