Updated on 2024-09-20 GMT+08:00
Deleting a RocketMQ Instance
For pay-per-use RocketMQ instances, you can delete one or more of them in batches on the console. For a yearly/monthly RocketMQ instance, if you no longer need it, choose More > Unsubscribe in the Operation column. RocketMQ instances will be automatically deleted upon unsubscription.
After a RocketMQ instance is deleted, the instance data will be deleted without backup.
The RocketMQ instance is pay-per-use and is in the Running, Faulty, or Frozen state.
  1. Log in to the console.
  2. Click in the upper left corner to select a region.
    Select the region where your RocketMQ instance is located.
  3. Click and choose Middleware > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
  4. Delete pay-per-use instances in either of the following ways:
    • In the row containing the RocketMQ instance you want to delete, click Delete.
    • Click a RocketMQ instance to go to the instance details page. In the upper right corner, choose More > Delete.
    • To delete multiple instances at a time, select the instances, and click Delete above the instance list.
    RocketMQ instances in the Creating or Restarting state cannot be deleted.
  5. In the Delete Instance dialog box, enter DELETE and click OK to delete the RocketMQ instance.
    It takes 1 to 60 seconds to delete a RocketMQ instance.
