User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
On this page
Show all
Help Center/
High Performance Computing/
HPC-S² User Guide/
FAQs/
Symptom
The master node is Running, but error message master node cannot reached is displayed.
Handling Methods
- Check that /usr/local/.hpccluster/role/.ssh/authorized_keys has been added to AuthorizedKeysFile in /etc/ssh/sshd_config.
- Check that authorized_keys exists in /usr/local/.hpccluster/role/.ssh/.
Parent topic: FAQs
