User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
On this page
Show all
Help Center/
High Performance Computing/
HPC-S² User Guide/
FAQs/
Symptom
If a compute node cannot be found or fails to be added to a cluster, the cluster cannot be deployed or created.
Handling Methods
- Delete the cluster. Manually bind an EIP to a compute node that was successfully created and then use it together with other compute nodes to create a new cluster.
- Delete the abnormal compute node to bring the cluster back to work.
Parent topic: FAQs
