Help Center/ High Performance Computing/ HPC-S² User Guide/ User Guide/ Node Management/ Restarting a Node
Updated on 2022-02-10 GMT+08:00
Restarting a Node
You can restart a faulty node to restore it.
Only nodes in the Running state can be restarted.
- Log in to the HPC-S² console.
- In the navigation pane on the left, choose Nodes.
- Select the target cluster from the cluster drop-down list.
- Locate the row where the node you want to restart resides and choose More > Restart in the Operation column.
- Click Yes.
- Wait until the node status changes to Running.
Parent topic: Node Management
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
