User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
On this page
Show all
Help Center/
High Performance Computing/
HPC-S² User Guide/
User Guide/
HPC Cluster Management/
Deleting an HPC Cluster
- If a cluster is no longer needed, you can delete it. If you do not select Delete cloud server when you delete the cluster, these servers will be retained and continue to be billed after the cluster is deleted. To stop billing for these cloud servers, manually delete pay-per-use servers and unsubscribe from yearly/monthly servers.
- If a cluster fails to be created, you can delete the cluster and do not select Delete cloud server. Then, use these servers to deploy a cluster again.
- If an exception occurs in a cluster and the cluster cannot be manually restored, you can delete the cluster and do not select Delete cloud server. Then, use these servers to deploy a cluster again.
Precautions
- The EIP bound to the cluster will continue to be billed after the cluster is deleted. You need to manually delete the EIP to stop billing.
- Data disks attached to nodes in the cluster will continue to be billed after the cluster is deleted, even if you select Delete cloud server when deleting the cluster. You need to manually delete the data disks to stop billing.
- Log in to the HPC-S² console.
- In the navigation pane on the left, choose Clusters.
- In the cluster list, locate the row where the cluster you want to delete, and choose More > Delete in the Operation column. On the confirmation page, whether option Delete cloud server is available depends on the billing mode of the cluster you want to delete.
Parent topic: HPC Cluster Management
