User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
Help Center/
High Performance Computing/
HPC-S² User Guide/
User Guide/
Viewing the Cluster Deployment Progress/
Viewing the Scale-In Progress of an HPC Cluster
After you submit a request for scaling in an HPC cluster, you can view the scale-in progress on the HPC-S² console.
- Log in to the HPC-S² console.
- In the navigation pane on the left, choose Clusters.
- In the cluster list, locate the row where the cluster you want to view resides and click View Progress in the Operation column.
On the displayed page, set Log Type to Manual scale-in and view the scale-in progress.
Parent topic: Viewing the Cluster Deployment Progress
