MPICH
This section describes how to run MPICH (version mpich-3.3.2 is used as an example) in a BMS cluster.
- Password-free login has been configured between BMSs in the cluster.
- MPICH has been installed on all BMSs in the cluster.
- Disable the firewall.
- Modify the configuration file.
- Log in to any BMS in the cluster and run the following command to add the hosts configuration file:
Add the private network IP addresses and hostnames of all BMSs in the cluster. For example, run the following commands:
192.168.1.138 bms-arm-ib-0001
192.168.1.45 bms-arm-ib-0002
- Run the following command to add the hostfile file:
$vi hostfile
Add the hostnames of all BMSs in the cluster and the number of cores (for example, 2 cores).
bms-arm-ib-0001:2
bms-arm-ib-0002:2
- Log in to all BMSs in the cluster and repeat 2.a to 2.b.
- Run the executable file on a BMS through MPICH.
$ mpirun -np 2 -hostfile /home/rhel/hostfile /home/rhel/hello
Figure 2 Successful execution of MPICH in the BMS cluster
Specify the path of hostfile when running it. The path of the executable file hello must be absolute. All executable files in the cluster must be in the same directory.
