User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
Show all
Community Open MPI
This section describes how to install and use community Open MPI (version 4.0.2 is used as an example) on a BMS.
Perform the operations on each BMS in a cluster.
Password-free login has been configured between BMSs in the cluster.
- Install Open MPI.
- Download community Open MPI of version openmpi-4.0.2.tar.bz2.
Download path: https://download.open-mpi.org/release/open-mpi/v4.0/openmpi-4.0.2.tar.bz2
- Copy the downloaded software package to a directory, /home/rhel is recommended, on the BMS.
- Run the following commands to decompress the software package:
# tar -xzvf openmpi-4.0.2.tar.bz2
# cd openmpi-4.0.2
- Install desired dependency packages. Ensure that the BMS can access the Internet before the installation.
# yum install binutils-devel.x86_64 gcc-c++ autoconf automake libtool
Figure 1 Successful installation of dependency packages - Run the following commands to install and compile Open MPI:
# ./openmpi-4.0.2/configure --prefix=/opt/openmpi-402--enable-mpirun-prefix-by-default --enable-mpi1-compatibility --with-ucx=/opt/ucx160
# make -j 128 && make install
Figure 2 Successful installation of Open MPI
- Configure MPI environment variables.
- Add the following environment variables in ~/.bashrc as a common user:
export PATH=$PATH:/opt/openmpi-310/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/openmpi-310/lib
- Run the following command to import MPI environment variables:
- Run the following command to check whether the MPI environment variables are correct:
If information shown in Figure 3 is displayed, the environment variables have been correctly configured.
- Run community Open MPI on a BMS.
- Run the following commands to generate an executable file:
$ vi hello.c
Edit the following content:
#include<mpi.h> #include<stdio.h> int main(int argc, char** argv){ //Initialize the MPI environment MPI_Init(NULL, NULL); //Get the number of processes int world_size; MPI_Comm_size(MPI_COMM_WORLD, &world_size); //Get the rank of the process int world_rank; MPI_Comm_rank(MPI_COMM_WORLD, &world_rank); //Get the name of the processor char processor_name[MPI_MAX_PROCESSOR_NAME]; int name_len; MPI_Get_processor_name(processor_name, &name_len); //Print off a hello world message. printf("Hello world from processor %s, rank %d"" out of %d processors\n",processor_name, world_rank, world_size); //Finalize the MPI environment. MPI_Finalize(); }
$ mpicc hello.c -o hello
NOTICE:
The hello.c file varies depending on MPI versions. You are required to re-compile the hello.c file by running the mpicc hello.c -o hello command, regardless of the MPI version.
$ mpirun -np 2 /home/rhel/hello
If information shown in Figure 4 is displayed, community Open MPI is running on the BMS.
