Help Center/ High Performance Computing/ User Guide/ Typical Applications in the BMS Scenario/ Installing and Using MPIs (Kunpeng BMS)/ MPIs Supported in the Kunpeng BMS Scenario
Updated on 2022-05-09 GMT+08:00
The following MPIs are supported in the Kunpeng BMS scenario:
- Built-in OpenMPI of the IB driver
- Community Open MPI
- MPICH
Install and use an MPI as needed.
Parent topic: Installing and Using MPIs (Kunpeng BMS)
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
