On this page
Platform MPI
Updated on 2022-05-09 GMT+08:00
This section describes how to run Platform MPI (version platform_mpi- 09.01.04.03r-ce.bin is used as an example) in a BMS cluster.
  • Password-free login has been configured between BMSs in the cluster.
  • Platform MPI has been installed on all BMSs in the cluster.
  1. Disable the firewall.
    1. Log in to a BMS in the cluster.
    2. Run the following command to disable the BMS firewall:
      # service firewalld stop
      # iptables -F
    3. Run the following command to check whether the firewall has been disabled:
      # service firewalld status
      Figure 1 Disabled firewall
    4. Log in to all other BMSs in the cluster and repeat 1.b to 1.c to disable firewalls on all BMSs.
  2. Modify the configuration file.
    2. Run the following command to obtain the BMS hostname:
      $ hostname
      Figure 2 Viewing the BMS hostname
    3. Log in to all other BMSs in the cluster and repeat 1.b to 2.b to obtain hostnames of all BMSs.
    4. Log in to a BMS in the cluster.
    5. Run the following command to add the hosts configuration file:
      # vi /etc/hosts
      Add the private network IP addresses and hostnames of all BMSs in the cluster. For example, run the following commands:
      192.168.0.1 bms-0004
      192.168.0.2 bms-0005
    6. Run the following command to add the hostfile file:
      $vi hostfile
      Add hostnames of all BMSs in the cluster, for example:
      bms-0004
      bms-0005
    7. Log in to other BMSs in the cluster and repeat 2.e to 2.f.
  3. Run the following command to run Platform Open MPI in the BMS cluster:
    $ mpirun -np 12 -machinefile hostfile /home/rhel/hello
    Figure 3 Successful execution of Platform MPI in the BMS cluster
    Specify the path of hostfile when running it. The path of the executable file hello must be absolute. All executable files in the cluster must be in the same directory.
