User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
Show all
Community Open MPI
This section describes how to run community Open MPI (version 3.1.1 is used as an example) in a BMS cluster.
- Password-free login has been configured between BMSs in the cluster.
- Community Open MPI has been installed on all BMSs in the cluster.
- Disable the firewall.
- Modify the configuration file.
- Log in to a BMS in the cluster.
- Run the following command to obtain the BMS hostname:
Figure 2 Viewing the BMS hostname
- Log in to all other BMSs in the cluster and repeat 1.b to 2.b to obtain hostnames of all BMSs.
- Run the following command to add the hosts configuration file:
Add the private network IP addresses and hostnames of all BMSs in the cluster. For example, run the following commands:
192.168.0.1 bms-0004
192.168.0.2 bms-0005
- Run the following command to add the hostfile file:
$vi hostfile
Add hostnames of all BMSs in the cluster, for example:
bms-0004
bms-0005
- Log in to other BMSs in the cluster and repeat 2.e to 2.f.
- Log in to any BMS and run the community Open MPI.
For example, there are two BMSs in the cluster. Then, run the following command:
$ mpirun -np 2 --pernode -hostfile hostfile /home/rhel/hello
Figure 3 Successful execution of community Open MPI in the clusterNOTE:
Specify the path of hostfile when running it. The path of the executable file hello must be absolute. All executable files in the cluster must be in the same directory.
