Open MPI Delivered with the IB Driver
This section describes how to run Open MPI (version 3.1.0rc2 is used as an example) delivered with the IB driver in a BMS cluster.
- Password-free login has been configured between BMSs in the cluster.
- Open MPI delivered with the IB driver has been installed on all BMSs in the cluster.
- Disable the firewall.
- Modify the configuration file.
- Log in to a BMS in the cluster.
- Run the following command to obtain the BMS hostname:
Figure 2 Viewing the BMS hostname
- Log in to all other BMSs in the cluster and repeat 2.a to 2.b to obtain hostnames of all BMSs.
- Run the following command to add the hosts configuration file:
Add the private network IP addresses and hostnames of all BMSs in the cluster. For example, run the following commands:
192.168.0.1 bms-0004
192.168.0.2 bms-0005
- Run the following command to add the hostfile file:
$vi hostfile
Add hostnames of all BMSs in the cluster, for example:
bms-0004
bms-0005
- Log in to all BMSs in the cluster and repeat 2.e to 2.f.
- Run MPI benchmark.
- Perform the following command on any BMS to check whether the hostfile file has been configured:
$ mpirun -np 2 -pernode --hostfile hostfile -mca btl_openib_if_include "mlx5_0:1" -x MXM_IB_USE_GRH=y hostname
If the hostnames of all BMSs in the cluster are displayed, as shown in Figure 3, the hostfile file has been configured.
- Run the MPI benchmark on any BMS with the hostfile path specified.
For example, there are two BMSs in the cluster. Then, run the following command:
$ mpirun -np 2 -pernode --hostfile hostfile -mca btl_openib_if_include "mlx5_0:1" -x MXM_IB_USE_GRH=y /usr/mpi/gcc/openmpi-3.1.0rc2/tests/imb/IMB-MPI1 PingPong
If information shown in Figure 4 is displayed, Open MPI delivered with the IB driver is running in the cluster.
