On this page
Platform MPI
Updated on 2022-05-09 GMT+08:00
This section describes how to install and use Platform MPI (version platform_mpi- 09.01.04.03r-ce.bin is used as an example) in a BMS cluster.
Perform this operation on each BMS in a cluster.
Password-free login has been configured between BMSs in the cluster.
  1. Install Platform MPI.
    1. Download the software package, such as platform_mpi- 09.01.04.03r-ce.bin.
    2. Run the following command to install the dependency package:
      # yum install glibc.i686 libgcc-4.8.5-11.el7.i686 libgcc_s.so.1
    3. Run the following command to assign execution permissions:
      #chmod +x platform_mpi-09.01.04.03r-ce.bin
    4. Install Platform MPI.
      # ./platform_mpi-09.01.04.03r-ce.bin
      Platform MPI is installed in /opt/ibm/platform_mpi by default.
      Figure 1 Installed Platform MPI
  2. Configure environment variables.
    1. Run the following command to obtain the pkey:
      # cat /sys/class/infiniband/mlx5_0/ports/1/pkeys/* | grep -v 0000
      Figure 2 Obtaining the pkey
    2. Add the following data to ~/.bashrc as a common user:
      export MPI_ROOT=/opt/ibm/platform_mpi
      export PATH=$MPI_ROOT/bin:$PATH
      export LD_LIBRARY_PATH=/opt/ibm/platform_mpi/lib/linux_amd64
      export MPI_IB_PKEY=pkey obtained in 2.a
      $source ~/.bashrc
      If there are multiple pkeys, use a comma to separate them.
    3. Run the following command to check whether the environment variables have been configured:
      # which mpirun
      Figure 3 Viewing the environment variables
  3. Run Platform MPI on a BMS.
    1. Run the following command to re-compile the hello.c file:
      $ mpicc hello.c -o hello
    2. Run the following command to run Platform MPI on a BMS:
      $ mpirun -np 2 /home/rhel/hello
      Figure 4 Running Platform MPI on a BMS
