Intel MPI
This section describes how to install and use Intel MPI (version l_mpi_2018.0.128 is used as an example) in a BMS cluster.
Perform this operation on each BMS in a cluster.
Password-free login has been configured between BMSs in the cluster.
- Install Intel MPI.
- Download Intel MPI.
Download path: https://software.intel.com/en-us/intel-mpi-library
- Decompress and install Intel MPI.
For example, run the following commands to decompress and install l_mpi_2018.0.128.tgz:
# tar -xvf l_mpi_2018.0.128.tgz
# cd l_mpi_2018.0.128/
# ./install.sh
Figure 1 Installed Intel MPI
- Configure environment variables.
- Run the following command to check whether environment variables have been imported:
$ which mpirun
If information shown in Figure 2 is displayed, the environment variables have been imported.
- Run Intel MPI on a BMS.
