Open MPI Delivered with the IB Driver
This section describes how to install and use Open MPI (version 3.1.0rc2 is used as an example) delivered with the IB driver on a BMS.
Perform the operations on each BMS in a cluster.
Password-free login has been configured between BMSs in the cluster.
- Check whether the IB driver has been installed.
- Install the IB driver.
- Download the installation package MLNX_OFED_LINUX-4.3-1.0.1.0-rhel7.3-x86_64.tgz.
Download path: https://network.nvidia.com/products/infiniband-drivers/linux/mlnx_ofed/
Figure 2 IB driver download center
- Run the following commands to install the software package:
# tar -xvf MLNX_OFED_LINUX-4.3-1.0.1.0-rhel7.3-x86_64.tgz
# cd MLNX_OFED_LINUX-4.3-1.0.1.0-rhel7.3-x86_64
# ./mlnxofedinstall
- Configure environment variables.
- Use VIM to open the ~/.bashrc file and add the following data to the file:
export PATH=$PATH:/usr/mpi/gcc/openmpi-3.1.0rc2/bin
export LD_LIBRARY_PATH=/usr/mpi/gcc/openmpi-3.1.0rc2/lib64
- Run the following command to check whether the MPI environment variables are correct:
If information shown in Figure 3 is displayed, environment variables have been configured.
- Run the following command to run Open MPI delivered with the IB driver on a BMS:
$ mpirun -np 2 -mca btl_openib_if_include "mlx5_0:1" -x MXM_IB_USE_GRH=y /usr/mpi/gcc/openmpi-3.1.0rc2/tests/imb/IMB-MPI1 PingPong
Figure 4 Running the Open MPI on a BMS
