User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
On this page
Show all
Help Center/
High Performance Computing/
User Guide/
Typical Applications in the BMS Scenario/
Installing and Using MPIs (x86 BMS)/
MPIs Supported in the BMS Scenario
The following MPIs are supported in the BMS scenario:
- Built-in OpenMPI of the IB driver
- Community OpenMPI
- Spectrum MPI
- Intel MPI
- Platform MPI
Install and use an MPI as needed.
Parent topic: Installing and Using MPIs (x86 BMS)
