Help Center/ High Performance Computing/ User Guide/ Typical Applications in the BMS Scenario/ Configuring Password-free Login Between BMSs in a Cluster
Updated on 2022-05-09 GMT+08:00
This section describes how to configure a BMS cluster to enable password-free login between BMSs in the cluster.
Background
$: indicates performing an operation as a common user.
#: indicates performing an operation as an administrator.
Run the sudo su command to switch from a common user to an administrator.
A BMS has been created and an EIP has been bound to the BMS.
  1. Use PuTTY and a key pair to log in to any BMS in the cluster.
  2. Run the following command to disable user logout upon system timeout:
    # TMOUT=0
  3. Copy the BMS key file in .pem format to the .ssh directory and name it id_rsa.
    $ cd ~/.ssh
    $ mv *.pem id_rsa
  4. Run the following command to assign permissions of the key file:
    $ sudo chmod 600 id_rsa
  5. Run the following command to log in to the BMS using SSH and check whether you can log in to the BMS without a password:
    $ ssh localhost
    Figure 1 Password-free login to a BMS
    If information shown in Figure 1 is displayed and you can log in to the BMS without a password, the permissions have been assigned.
  6. Log in to other BMSs in the cluster and repeat steps 1 to 5.
  7. Run the following commands to check whether the tested BMSs can be logged in from each other without a password:
    $ ssh Username@SERVER_IP
