User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
Show all
Open MPI Delivered with the IB Driver
This section describes how to run the built-in MPI (version 3.0.0rc6) of the IB driver on a configured ECS.
- An ECS equipped with InfiniBand NICs has been created, and an EIP has been bound to it.
- Multiple ECSs have been created using a private image.
- Use PuTTY and a key pair to log in to the ECS.
Ensure that the username specified during ECS creation is used to establish the connection.
- Run the following command to disable user logout upon system timeout:
- Run the following command to check whether the ECSs to be tested can be logged in to from each other without a password:
- Run the following commands to disable the firewall of the ECS:
# service firewalld stop
- Run the following command to log out of the root account:
# exit
- Run the following command to add the hostfile file:
# vi hostfile
Add the IP addresses or names of the ECSs (IP addresses corresponding with the names of ECSs are contained in the /etc/hosts directory). For example, add the following IP addresses:
# cat hostfile
192.168.0.1
192.168.0.2
- Run the following command to run the hostname command in the cluster:
# mpirun --allow-run-as-root -np <hostfile_node_number> -pernode --hostfile hostfile hostname
Figure 1 Running the hostname command in the cluster - Modify hostfile and run MPI benchmark with the path of hostfile specified.
For example, to modify the hostfile file and run MPI benchmark on two ECSs, run the following command:
# mpirun --allow-run-as-root -np 2 -pernode --hostfile /root/hostfile /usr/mpi/gcc/openmpi-3.0.0rc6/tests/imb/IMB-MPI1 PingPong
Run Intel MPI benchmark in a cluster containing two nodes. In the RDMA network, the minimum latency is less than 1.5 us.
#------------------------------------------------------------ # Intel (R) MPI Benchmarks 4.1, MPI-1 part #------------------------------------------------------------ # Date : Mon Jul 16 10:12:51 2018 # Machine : x86_64 # System : Linux # Release : 3.10.0-514.10.2.el7.x86_64 # Version : #1 SMP Fri Mar 3 00:04:05 UTC 2017 # MPI Version : 3.1 # MPI Thread Environment: # New default behavior from Version 3.2 on: # the number of iterations per message size is cut down # dynamically when a certain run time (per message size sample) # is expected to be exceeded. Time limit is defined by variable # "SECS_PER_SAMPLE" (=> IMB_settings.h) # or through the flag => -time # Calling sequence was: # /usr/mpi/gcc/openmpi-3.0.0rc6/tests/imb/IMB-MPI1 PingPong # Minimum message length in bytes: 0 # Maximum message length in bytes: 4194304 # # MPI_Datatype : MPI_BYTE # MPI_Datatype for reductions : MPI_FLOAT # MPI_Op : MPI_SUM # # # List of Benchmarks to run: # PingPong #--------------------------------------------------- # Benchmarking PingPong # #processes = 2 #--------------------------------------------------- #bytes #repetitions t[usec] Mbytes/sec 0 1000 1.87 0.00 1 1000 1.93 0.49 2 1000 1.78 1.07 4 1000 1.79 2.13 8 1000 1.77 4.31 16 1000 1.78 8.57 32 1000 1.79 17.09 64 1000 1.85 33.02 128 1000 1.90 64.12 256 1000 2.40 101.58 512 1000 2.53 192.90 1024 1000 2.85 342.61 2048 1000 3.23 604.14 4096 1000 4.32 904.98 8192 1000 5.89 1325.65 16384 1000 8.48 1842.47 32768 1000 12.50 2500.57 65536 640 21.79 2867.89 131072 320 34.28 3646.50 262144 160 42.19 5925.52 524288 80 66.55 7513.14 1048576 40 114.95 8699.54 2097152 20 213.71 9358.48 4194304 10 402.59 9935.78 # All processes entering MPI_Finalize
- Deploy your MPI application in the Linux cluster and run the MPI application in the Linux cluster using the preceding method.
