Spectrum MPI
This section describes how to install and use IBM Spectrum MPI (for example, IBM Spectrum MPI v10.1).
IBM Spectrum MPI v10.1 supports the following OSs:
- IBM Spectrum MPI 10.1.0.1 Eval for x86_64 Linux
- Red Hat Enterprise Linux version 6.6 and later
- Red Hat Enterprise Linux version 7.1 and later
- SUSE Linux Enterprise Server version 11 SP4
- SUSE Linux Enterprise Server version 12 and later
- IBM Spectrum MPI 10.1.0.2 Eval for Power 8 Linux
- Red Hat Enterprise Linux version 7.3 and later
You have configured the ECS password-free login.
- Obtain the software package.
- Download the IBM Spectrum MPI software package from the following website:
Download path: https://www-01.ibm.com/marketing/iwm/iwm/web/preLogin.do?source=swerpsysz-lsf-3
The software package contains the license and software packages. The following are examples:
smpi_lic_s-10.1Eval-rh7_Sep15.x86_64.rpm
ibm_smpi-10.1.0.3eval_170901-rh7_Apr11.x86_64.rpm
- Download the desired HPC-X toolkit.
In the EDR SR-IOV scenario, the IBM MPI relies on the MXM library provided by the HPC-X toolkit. Download the desired version of the HPC-X toolkit based on the ECS OS and IB driver versions. An example of the HPC-X toolkit version is hpcx-v2.0.0-gcc-MLNX_OFED_LINUX-4.2-1.2.0.0-redhat7.3-x86_64.tbz.
Download path: https://developer.nvidia.com/networking/hpc-x
- Install the HPC-X toolkit.
- Upload the HPC-X package downloaded in 1 to the ECS with an MPI.
- Run the following command to decompress the HPC-X toolkit:
$ tar xvf hpcx-v2.0.0-gcc-MLNX_OFED_LINUX-4.2-1.2.0.0-redhat7.3-x86_64.tbz
- Run the following command to configure the HPC-X environment variables:
$ cd hpcx-v2.0.0-gcc-MLNX_OFED_LINUX-4.2-1.2.0.0-redhat7.3-x86_64
$ export HPCX_HOME=$PWD
- Install IBM Spectrum MPI.
- Upload the MPI package downloaded in 1 to the ECS with an MPI.
- Run the following command to switch to user root:
$ sudo su -
- Run the following command to configure environment variables:
- If you choose to automatically accept the IBM Spectrum MPI installation license agreement, run the following command:
- If you choose to manually accept the IBM Spectrum MPI installation license agreement, run the following command:
- Install the license.
# rpm -ivh ibm_smpi_lic_s-10.1Eval-rh7_Sep15.x86_64.rpm
Figure 1 Manually accepting the IBM Spectrum MPI installation license agreement
Run the following command as prompted:
# sh /opt/ibm/spectrum_mpi/lap_se/bin/accept_spectrum_mpi_license.sh
- Run the following command to install the software:
# rpm -ivh ibm_smpi-10.1.0.3eval_170901-rh7_Apr11.x86_64.rpm
Figure 2 Installing the software
- Configure MPI environment variables.
- By default, Spectrum MPI is installed in the /opt/ibm/spectrum_mpi directory. In this case, you need to configure the following environment variables:
export MPI_ROOT=/opt/ibm/spectrum_mpi
export LD_LIBRARY_PATH=$MPI_ROOT/lib:$LD_LIBRARY_PATH
export PATH=$MPI_ROOT/bin:$PATH
export MANPATH=$MPI_ROOT/share/man:$MANPATH
unset MPI_REMSH
- Run the following command to check whether the environment variables have been imported:
Figure 3 Checking MPI environment variables
- Run the following command on an ECS to run the executable file through Spectrum MPI:
- Run the following command to edit the file:
# vi hello.c
Edit the following content:
#include<mpi.h> #include<stdio.h> int main(intargc, char**argv){ //Initialize the MPI environment MPI_Init(NULL, NULL); //Get the number of processes int world_size; MPI_Comm_size(MPI_COMM_WORLD, &world_size); //Get the rank of the process int world_rank; MPI_Comm_rank(MPI_COMM_WORLD, &world_rank); //Get the name of the processor char processor_name[MPI_MAX_PROCESSOR_NAME]; int name_len; MPI_Get_processor_name(processor_name, &name_len); //Print off a hello world message printf("Hello world from processor %s, rank %d"" out of %d processors\n", processor_name, world_rank, world_size); //FinalizetheMPIenvironment. MPI_Finalize(); } - Run the following command to generate an executable file (for example in the /home/linux directory).
# mpicc hello.c -o spe_hello
The hello file varies depending on the MPI version. If you update the MPI version, run the # mpicc hello.c -o spe_hello command to generate a new executable file.
- Run the following command to run Spectrum MPI on an ECS:
# mpirun --allow-run-as-root -np 2 /root/spe_hello
Information shown in Figure 4 is displayed.
