Built-in OpenMPI of the IB Driver
This section describes how to install and use the built-in OpenMPI of the IB driver (for example, 3.0.0rc6).
You have configured the ECS password-free login.
- Check whether the IB driver has been installed.
- Use PuTTY and a key pair to log in to the ECS.
- Run the following command to switch to user root:
$ sudo su
- Run the following command to disable user logout upon system timeout:
- Run the following commands to check whether the IB driver has been installed:
# ls /usr/mpi/gcc/openmpi-3.0.0rc6/bin/mpirun
- Download and install the IB driver.
Download the required version of InfiniBand NIC driver from the Mellanox official website https://network.nvidia.com/products/infiniband-drivers/linux/mlnx_ofed/ and install the driver by following the instructions provided.
For example, for an ECS running CentOS 7.3, download the MLNX_OFED_LINUX-4.2-1.2.0.0-rhel7.3-x86_64.tgz installation package and run the following commands to install the IB driver:
# yum install tk tcl
# tar -xvf MLNX_OFED_LINUX-4.2-1.2.0.0-rhel7.3-x86_64.tgz
# cd MLNX_OFED_LINUX-4.2-1.2.0.0-rhel7.3-x86_64/
# ./mlnxofedinstall
- Configure environment variables.
- Run the following commands to configure the ~/.bashrc file using the vim editor and add the following content:
export PATH=$PATH:/usr/mpi/gcc/openmpi-3.0.0rc6/bin
export LD_LIBRARY_PATH=/usr/mpi/gcc/openmpi-3.0.0rc6/lib64
- Run the following command to import MPI environment variables:
- Run the following command to check whether the MPI environment variables are correct:
If information shown in Figure 2 is displayed, the environment configuration is correct.
- Run the following command to run Intel MPI benchmark on an ECS:
# mpirun --allow-run-as-root -np 2 /usr/mpi/gcc/openmpi-3.0.0rc6/tests/imb/IMB-MPI1 PingPong
Information similar to the following is displayed:
#------------------------------------------------------------ # Intel (R) MPI Benchmarks 4.1, MPI-1 part #------------------------------------------------------------ # Date : Mon Jul 16 10:11:14 2018 # Machine : x86_64 # System : Linux # Release : 3.10.0-514.10.2.el7.x86_64 # Version : #1 SMP Fri Mar 3 00:04:05 UTC 2017 # MPI Version : 3.1 # MPI Thread Environment: # New default behavior from Version 3.2 on: # the number of iterations per message size is cut down # dynamically when a certain run time (per message size sample) # is expected to be exceeded. Time limit is defined by variable # "SECS_PER_SAMPLE" (=> IMB_settings.h) # or through the flag => -time # Calling sequence was: # /usr/mpi/gcc/openmpi-3.0.0rc6/tests/imb/IMB-MPI1 PingPong # Minimum message length in bytes: 0 # Maximum message length in bytes: 4194304 # # MPI_Datatype : MPI_BYTE # MPI_Datatype for reductions : MPI_FLOAT # MPI_Op : MPI_SUM # # # List of Benchmarks to run: # PingPong #--------------------------------------------------- # Benchmarking PingPong # #processes = 2 #--------------------------------------------------- #bytes #repetitions t[usec] Mbytes/sec 0 1000 0.24 0.00 1 1000 0.25 3.89 2 1000 0.23 8.17 4 1000 0.23 16.25 8 1000 0.23 32.48 16 1000 0.23 65.98 32 1000 0.26 115.35 64 1000 0.26 232.92 128 1000 0.38 320.59 256 1000 0.44 554.35 512 1000 0.54 902.98 1024 1000 0.64 1537.63 2048 1000 0.85 2298.79 4096 1000 1.28 3057.93 8192 1000 2.28 3426.14 16384 1000 1.41 11052.14 32768 1000 2.05 15218.39 65536 640 3.31 18882.34 131072 320 6.57 19036.27 262144 160 15.12 16535.96 524288 80 32.90 15195.74 1048576 40 64.62 15476.02 2097152 20 122.83 16282.06 4194304 10 242.95 16463.95 # All processes entering MPI_Finalize
