Creating a Workspace
Workspace is a way of isolating resources, such as models and skills, between different users.
Resource Isolation
Each Huawei Cloud account or IAM account has a default workspace, which can be used to view all resources created by the current account on Huawei HiLens.
The table below lists resources that are isolated between different workspaces.
Navigation Tree |
Isolated Resource |
Device Management > Devices |
Registered HiLens Kit devices and device resources, including skills, cameras, alarms, and firmware versions |
Skill Development > Models |
Models imported (converted) to Huawei HiLens |
Skill Development > Skills |
Skill resource created on the console |
Data Management (Beta) |
Logs generated when devices in different workspaces run skills |
The table below lists resources that are shared by all workspaces.
Navigation Tree |
Shared Resource |
Skill Market |
Skills that can be shared in the skill market and skills purchased by the current account |
Device Management > Products |
Newly created cameras with HiSilicon Hi35xx series chips on Huawei HiLens |
Skill Development > Skill Templates |
Templates built in Huawei HiLens and templates added to My Favorites by the current account |
- Log in to the Huawei HiLens management console. In the navigation pane, choose Create Workspace from the drop-down list box under Current Workspace.
The Create Workspace page is displayed.
Figure 1 Creating a workspace
- Enter the workspace name and description, and click Create Now in the lower right corner. The Workspaces page is displayed. You can view the newly created workspace.
The workspace description cannot contain the following characters: #~^$%&*<>{}[]\/|
Figure 2 Creating a workspace-0
Allocating Workspace
You can move devices and their resources such as skills and cameras from a workspace to another workspace.
This section uses test and test2 as an example to describe how to allocate workspace. test is the original workspace where device resources are located and test2 is the target workspace for device resource allocation .
- Log in to the Huawei HiLens management console. In the navigation pane, select the test workspace from the drop-down list box under Current Workspace.
- In the navigation tree on the left, choose Device Management > Devices, select the devices to be allocated, and click the device cards.
The device details page is displayed.
- Click Allocate Workspace in the upper right corner.
The Allocate Workspace dialog box is displayed.
- Select workspace test2 and click OK.
A message is displayed in the upper right corner, indicating that the devices are allocated successfully. You can switch to the workspace test2 and view the allocated device resources on the Device Management > Devices page.
Modifying a Workspace
Currently, you can change the name and description of a custom workspace, but cannot change the name of the default workspace.
- Log in to the Huawei HiLens console. In the navigation pane, choose Workspaces.
Figure 3 Workspace
- Select the workspace to be modified and click Modify in the Operation column.
- In the dialog box, modify the workspace description, and click OK.
Figure 4 Modifying a workspace
Deleting a Workspace
You can delete a workspace that is no longer used to release resources. The default workspace cannot be deleted.
- Log in to the Huawei HiLens console. In the navigation pane, choose Workspace.
The Workspace page is displayed.
- Select the workspace to be deleted and click Delete in the Operation column.
Figure 5 Deleting a workspace
- Confirm the information in the dialog box and click OK.
Follow-up Operations
When there are several workspaces, you can select a workspace from the drop-down list under Current Workspace in the navigation pane to use your Huawei HiLens resources. For more information, see Procedures for Using HiLens.
