On this page
Show all
Help Center/ Huawei HiLens/ User Guide/ TensorFlow Operator Boundaries
Updated on 2024-09-30 GMT+08:00
Table 1 shows the boundaries of TensorFlow operators supported by .om models.
Table 1 TensorFlow operator boundaries
No.
Python API
C++ API
Boundary
tf.nn.avg_pool
AvgPool
Type: Mean
[Parameter]
  • value: 4D tensor of type float32, with shape [batch, height, width, channels]
  • ksize: list or tuple of four integers, each value corresponding to the window size for each dimension of the input tensor.
  • strides: list or tuple of four integers. Each value corresponding to the stride of the sliding window for each dimension of the input tensor.
  • padding: string, either VALID or SAME
  • data_format: string, either NHWC (default) or NCHW
  • name: (optional) string
[Constraint]
  • kernelH ≤ inputH + padTop + padBottom
  • kernelW ≤ inputW + padLeft + padRight
  • padTop < windowH
  • padBottom < windowH
  • padLeft < windowW
  • padRight < windowW
In addition to common restrictions, the following restrictions must be satisfied.
The global pooling mode supports only the following scenarios:
  • outputH == 1 && outputW == 1 && kernelH ≥ inputH && kernelW ≥ inputW
  • inputH*inputW ≤ 10,000
[Output]
Tensor of the identical data type as value
[Quantitative tool support]
Yes
2
tf.nn.max_pool
MaxPool
Same as tf.nn.avg_pool
3
tf.nn.conv2d
Conv2D
[Parameter]
  • value: 4D tensor, with shape [batch, height, width, channels]
  • Data type: float32
  • filter: constant tensor, with same data type and dimensions as value, with shape [filter_height, filter_width, in_channels, out_channels]
  • strides: non-null list or tuple of four integers, each value corresponding to the stride of the sliding window for each dimension of the input tensor
  • padding: non-null string, either VALID or SAME
  • data_format: non-null string, either NHWC (default) or NCHW
  • dilations: (optional) list of four integers, default to [1,1,1,1], each value corresponding to a dimension. If k > 1, k – 1 units are skipped at the corresponding dimension in filtering. The dimension sequence is determined by data_format. The values of batch and depth of dilations must be 1.
[Constraint]
  • (inputW + padWHead + padWTail) ≥ (((FilterW-1) x dilationW) + 1)
  • (inputW + padWHead + padWTail)/StrideW + 1 ≤ INT32_MAX
  • (inputH + padHHead + padHTail) ≥ (((FilterH-1) x dilationH) + 1)
  • (inputH + padHHead + padHTail)/StrideH + 1 ≤ INT32_MAX
  • 0 ≤ Pad < 256, 0 < FilterSize < 256, 0 < Stride < 64, 1 ≤ dilationsize < 256
[Output]
Yes
4
tf.concat
Concat
[Parameter]
  • values: list of tensor objects or a single tensor. The values of dimensions must be the same except the dimensions to be concatenated.
  • axis: 0D tensor of type int32, specifying the dimension to be concatenated. The value range is [–rank(values), rank(values)]. As in Python, indexing for axis is 0-based. Positive axis in the range [0, rank(values)) refers to axis-th dimension, while negative axis refers to [axis + rank(values)]-th dimension.
[Constraint]
For the input tensor, the sizes of its dimensions must be the same except the dimension for concatenation.
The range of the input tensor count is [1, 1000].
[Output]
Tensor, resulting from concatenation of the input tensors
Yes
5
tf.matmul
MatMul
[Parameter]
  • a: non-constant tensor of type float32, rank ≥ 2
  • b: constant tensor with the same data type and rank as a
  • transpose_a: The value true indicates that a is transposed before multiplication.
  • transpose_b: The value true indicates that b is transposed before multiplication. If transpose_a is false, transpose_b is also false.
  • adjoint_a: The value true indicates that a is conjugated and transposed before multiplication.
  • adjoint_b: The value true indicates that b is conjugated and transposed before multiplication.
  • a_is_sparse: The value true indicates that a is treated as a sparse matrix.
  • b_is_sparse: The value true indicates that b is treated as a sparse matrix.
  • name: optional
[Constraint]
  • The transposing property of weight is false.
  • The multiplication of two tensors is not supported. Only one tensor by one constant is supported.
[Output]
Tensor of the identical data type as a and b
No
6
tf.nn.fused_batch_norm
FusedBatchNorm
[Parameter]
  • x: 4D tensor of type float32
  • scale: 1D tensor for scaling
  • offset: 1D tensor for bias
  • mean: 1D tensor for population mean used for inference
  • variance: 1D tensor for population variance used for inference
  • epsilon: small float number added to the variance of x
  • data_format: data format for x, either NHWC (default) or NCHW
  • is_training: bool, specifying whether the operation is used for training or inference
  • name: (optional) operation name
[Constraint]
shape of scale, bias, mean, and var: (1, C, 1, 1), with the C dimensions equal to that of the input
[Output]
  • y: 4D tensor for the normalized, scaled, offset x
  • batch_mean: 1D tensor for the mean of x
  • batch_var: 1D Tensor for the variance of x
No
7
tf.abs
Abs
[Parameter]
  • x: tensor or sparse tensor of type float32
[Constraint]
None
[Output]
Returns the absolute value of x, tensor or sparse tensor. The size and type are the same as those of x.
Yes
8
tf.image.resize_nearest_neighbor
ResizeNearestNeighbor
[Parameter]
  • images: 4D tensor of type float32, with shape [batch, height, width, channels] or 3D tensor of type float32 with shape [height, width, channels]
  • size: 1D 2-element constant tensor, indicating the new size for the images
  • method: ResizeMethod.NEARESTNEIGHBOR
  • align_corners: bool, default to False. The value True indicates that the centers of the 4 corner pixels of the input and output tensors are aligned and the values at the corner pixels are preserved.
[Constraint]
None
[Output]
Tensor of type float, with the identical shape as the input
No
9
tf.image.resize_bilinear
ResizeBilinear
[Parameter]
  • images: 4D non-constant tensor of type float32, with shape [batch, height, width, channels]
  • method: ResizeMethod.BILINEAR
[Constraint]
(outputH x outputW)/(inputH x inputW) > 1/7
[Output]
No
10
tf.cast
Cast
[Input]
Type: float32, int32, bool, int64, int16, int8, uint8, uint16, double
[Parameter]
  • x: Tensor, SparseTensor, or IndexedSlices
  • dtype: destination type, same as the data type of x
  • name: optional
[Constraint]
None
[Output]
Tensor, SparseTensor, or IndexedSlices with the same dtype and shape as the input
No
11
tf.nn.depthwise_conv2d
DepthwiseConv2dNative
[Parameter]
  • input: 4D
  • filter: 4D constant, with shape [filter_height, filter_width, in_channels, channel_multiplier]
  • strides: non-null list of four integers, each value corresponding to the stride of the sliding window for each dimension of the input tensor
  • rate: 1D of size 2. The dilation rate in which we sample input values across the height and width dimensions in atrous convolution. If i\t is greater than 1, then all values of strides must be 1.
  • data_format: data format for input, either NHWC (default) or NCHW
  • name: optional
[Constraint]
filterN = inputC = group
[Output]
4D tensor, with shape according to data_format. For example, for format NHWC, shape = [batch, out_height, out_width, in_channels * channel_multiplier]
Yes
12
tf.reshape
Reshape
[Parameter]
  • tensor: 1 tensor input
  • shape: constant tensor of type int64 or int, indicating the output shape
[Constraint]
None
[Output]
Tensor of the identical data type as input
Yes
13
tf.squeeze
Squeeze
[Parameter]
  • input: non-constant tensor
  • axis: list of ints, specifying the dimensions to be squeezed, default to []. It is an error to squeeze a dimension that is not 1.
  • squeeze_dims: (deprecated) exclusive with axis
[Constraint]
None
[Output]
Tensor, with the same data and type as input, but has one or more dimensions of size 1 removed.
Yes
14
tf.expand_dims
ExpandDims
[Parameter]
  • inuput: 1 tensor input
  • axis: 0D (scalar), specifying the dimension index of the extended input shape
  • name: name of the output tensor
  • dim: 0D (scalar), equivalent to axis (deprecated)
[Constraint]
None
[Output]
Tensor with the same data as input, but its shape has an additional dimension of size 1 added
Yes
15
tf.greater
Greater
[Parameter]
  • x: 1 tensor input
  • y: scalar
[Constraint]
Broadcasting is supported, so the shape of x and shape of y are compared. For a right-aligned dimension, if the values of xdim[i] and ydim[i] are not the same, one of them must be 1 or missing.
[Output]
Tensor of type bool
No
16
tf.nn.relu
Relu
[Parameter]
  • features: non-constant tensor
[Constraint]
None
[Output]
Tensor of the identical data type as features
Yes
17
tf.nn.relu6
Relu6
[Parameter]
[Constraint]
None
[Output]
Yes
18
tf.nn.leaky_relu
[Parameter]
  • features: non-constant tensor representing pre-activation values
  • alpha: slope of the activation function at x < 0
[Constraint]
None
[Output]
Activation value
Yes
19
tf.exp
exp
[Parameter]
  • x: tensor of type float32 or double
[Constraint]
None
[Output]
Tensor of the identical data type as x
No
20
tf.nn.conv2d_transpose
Conv2DBackpropInput
[Parameter]
  • value: 4D tensor with shape [batch, height, width, in_channels] for NHWC data format or [batch, in_channel, height, width] for NCHW data format
  • filter: 4D constant tensor with shape [height, width, output_channels, in_channels]
  • output_shape: 1D tensor, indicating the output shape
  • strides: non-null list of integers, each value corresponding to the stride of the sliding window for each dimension of the input tensor
  • data_format: non-null string, either NHWC or NCHW
  • name: (optional) output name
[Constraint]
  • group = 1
  • dilation = 1
  • filterH - padHHead - 1 ≥ 0
  • filterW - padWHead - 1 ≥ 0
Restrictions involving intermediate variables:
  1. a = ALIGN(filter_num, 16) x ALIGN(filter_c, 16) x filter_h x filter_w x 2
  2. If ALIGN(filter_c, 16)%32 = 0, a = a/2
  3. conv_input_width = (deconvolution input W – 1) x strideW + 1
  4. b = (conv_input_width) x filter_h x ALIGN(filter_num, 16) x 2 x 2
  5. a + b <= 1024*1024
[Output]
Yes
21
tf.sigmoid
Sigmoid
[Parameter]
  • x: 1 tensor input
[Constraint]
None
[Output]
Yes
22
tf.add
Add
[Parameter]
  • x: Tensor of type float32 or int32
  • y: Tensor of the identical data type as x. For two constant inputs, one of them is a scalar.
[Constraint]
If the two inputs have inconsistent dimensions, broadcasting (that is, dimension padding) is performed.
Broadcasting is supported in the following scenarios:
  • NHWC + NHWC, NHWC + scalar
  • NHWC + 1 1 1 1
  • NHWC + W, HWC + W, HW + W (W-based broadcasting)
  • NCHW + NH1C, HWC + H1C, HW + H1
  • HWC + 1 WC (H-based broadcasting)
The input sequence of the two tensors is not fixed.
[Output]
Tensor of the identical data type as y
Yes
23
tf.multiply
Multiply
Type: Mul
[Parameter]
  • y: Tensor of the identical data type as x. If two constants are input, their dimensions must be identical (scalar or 1D tensor)
[Constraint]
  • NHWC + 1 1 1 1
[Output]
1 tensor
Yes
24
tf.subtract
Subtract
Type: Sub
[Parameter]
  • x: 1 tensor input
  • y: Tensor of the identical data type as x, constant or non-constant
[Constraint]
  • NHWC + 1 1 1 1
[Output]
1 tensor
Yes
25
tf.nn.bias_add
BiasAdd
[Parameter]
  • value: non-constant tensor
  • bias: 1D constant tensor, with size matching the last dimension of value, of the same type as value unless value is a quantized type
  • data_format: string, either NHWC or NCHW
[Constraint]
  • C < 10,000
  • input and bias must have the same data layout.
  • When bias is added to the C dimension, the C dimensions of input and bias must of the same size.
[Output]
Yes
26
tf.nn.lrn
LRN
[Parameter]
  • input: 4D tensor of type float32
  • depth_radius: 0D of type int, default to 5, indicating the half-width of the 1D normalization window
  • bias: (optional) float, default to 1, indicating the offset (usually positive to avoid dividing by 0)
  • alpha: (optional) float, default to 1, indicating the scale factor, usually positive
  • beta: (optional) float, default to 0.5, indicating an exponent
[Constraint]
  • depth_radius is an odd number greater than 0.
  • Inter-channel:
    When depth_radius is within [1,15], alpha > 0.00001 and beta > 0.01; Otherwise, alpha and beta are of any values. When C > 1,776, depth_radius < 1,728.
[Output]
Yes
27
tf.nn.elu
Elu
[Parameter]
  • name: optional
[Constraint]
None
[Output]
No
28
tf.rsqrt
Rsqrt
[Parameter]
  • x: tensor input
  • name: optional
[Constraint]
None
[Output]
Yes
29
tf.log
Log
[Parameter]
  • name: optional
[Constraint]
None
[Output]
No
30
tf.tanh
Tanh
[Parameter]
  • x: non-constant tensor
  • name: optional
[Constraint]
None
[Output]
Yes
31
tf.slice
Slice
[Parameter]
  • input_: tensor input
  • begin: tensor of type int32 or int64
  • size: Tensor of type int32 or int64
  • name: optional
[Constraint]
The number of tensor elements cannot exceed INT32_MAX.
[Output]
Tensor of the identical data type as input_
Yes
32
tf.split
Split
[Parameter]
  • value: tensor input
  • num_or_size_splits: not supported
  • axis: integer, specifying the dimension along which to split
  • name: (optional), string
[Constraint]
None
[Output]
List of tensor objects resulting from splitting
Yes
33
tf.nn.softplus
Softplus
[Parameter]
  • features: Tensor of type float32
[Constraint]
None
[Output]
No
34
tf.nn.softsign
Softsign
[Parameter]
[Constraint]
None
[Output]
No
35
tf.pad
Excessive CPU usage usually means insufficient idle CPUs in the system.
[Parameter]
  • tensor: 4D tensor of type float32 and int32
  • paddings: constant tensor of type int32
  • mode: string, CONSTANT, REFLECT, or SYMMETRIC
  • constant_values: scalar pad value to use, of the identical data type as tensor.
[Constraint]
In CONSTANT mode: 0 ≤ PAD ≤ 128, 0 < W ≤ 3000
[Output]
Tensor of the identical data type as tensor
Yes
36
tf.fake_quant_with_min_max_vars
FakeQuantWithMinMaxVars
[Parameter]
  • inputs: Tensor of type float32
  • min: tensor of type float32
  • max: tensor of type float32
  • num_bits: scalar of type int, default to 8
  • narrow_range: (optional) bool, default to False
[Constraint]
-65,504 ≤ min ≤ 65,504, -65,504 ≤ max ≤ 65,504
[Output]
No
37
tf.reduce_max
Max
[Parameter]
  • input_tensor: Tensor, must be one of the following types: float32, int64, int32, uint8, uint16, int16, int8
  • axis: 1D list or scalar of type integer
  • keepdims: bool, indicating whether to retain reduced dimensions with length 1
  • reduction_indices: (deprecated) equivalent to axis
  • keep_dims: (deprecated) equivalent to keepdims
[Constraint]
  • When the input tensor has four dimensions: input axis = {3,{1,2,3}}, keepDims = true, H * W * 16 * 2 ≤ 16 * 1024
  • When the input tensor has two dimensions: input axis = {1,{1}}, keepDims = true, H * W * CEIL(C, 16) * 16 * 2 ≤ 16 * 1024
[Output]
Reduced Tensor of the identical data type as input_tensor
No
38
tf.strided_slice
StridedSlice
[Parameter]
  • input: 1 tensor
  • begin: 1D tensor of type int32
  • end: 1D tensor of type int32
  • strides: 1D tensor of type int32
  • begin_mask: scalar of type int32
  • end_mask: scalar of type int32
  • ellipsis_mask: scalar of type int32
  • new_axis_mask: scalar of type int32
  • var: variable corresponding to input_ or None
[Constraint]
strides ≠ 0
[Output]
No
39
tf.reverse
Reverse
[Parameter]
  • tensor: list of tensor objects
  • axis: int32 or int64, indicating the dimensions to reverse
[Constraint]
None
[Output]
No
40
tf.realdiv
RealDiv
[Parameter]
  • y: Tensor of type float32
[Constraint]
None
[Output]
Yes
41
tf.stack
Stack
[Parameter]
  • values: list of tensor objects with the same shape and type (float32 or int32)
  • axis: (mandatory) integer, indicating the axis to stack along, default to the first dimension
  • name: optional
[Constraint]
None
[Output]
Stacked tensor of the identical data type as values
Mandatory attributes: T, N, and axis
No
42
tf.unstack
Unpack
[Parameter]
  • value: tensor (rank > 0) to be unstacked, of type float32 or int32
  • num: integer, indicating the length of the dimension axis, default to None
  • axis: (mandatory) integer, indicating the axis to unstack along, default to the first dimension
  • name: optional
[Constraint]
None
[Output]
List of tensor objects unstacked from value
No
43
tf.transpose
Transpose
[Parameter]
  • a: tensor input
  • perm: permutation of the dimensions of a
  • name: optional
  • conjugate: (optional) bool, default to False. Setting it to True is mathematically equivalent to tf.conj(tf.transpose(input))
[Constraint]
None
[Output]
Resulting tensor after transposition
Yes
44
tf.space_to_batch_nd
SpaceToBatchND
[Parameter]
  • input: ND tensor with shape input_shape = [batch] + spatial_shape + remaining_shape, where spatial_shape has M dimensions. The following data types are supported: uint8, int8, int16, uint16, int32, int64, and float32
  • block_shape: 1D Tensor of type int32 or int64, with shape [M]. All values must be ≥ 1.
  • paddings: 2D tensor of type int32 or int64, with shape [M, 2]. All values must be ≥ 0.
[Constraint]
When the tensor rank is 4:
The length of blockShape must be 2, and the length of paddings must be 4.
  • Element value of blockShape ≥ 1; Element value of paddings ≥ 0
  • The padded H dimension is a multiple of blockShape[0], and the padded W dimension is a multiple of blockShape[1].
[Output]
No
45
tf.batch_to_space_nd
BatchToSpaceND
[Parameter]
  • crops: 2D tensor of type int32 or int64, with shape [M, 2]. All values must be ≥ 0.
[Constraint]
  • The element data type of blockShape and crops must be int32. When the dimension count of the tensor is 4, the length of blockShape must be 2, and the length of crops must be 4.
  • Element value of blockShape ≥ 1; Element value of crops ≥ 0; for the crops array: crop_start[i] + crop_end[i] < block_shape[i] * input_shape[i+1]
[Output]
Tensor of the identical data type as images
No
46
tf.extract_image_patches
ExtractImagePatches
[Parameter]
  • images: 4D tensor with shape [batch, in_rows, in_cols, depth], must be one of the following types: float32, int32, int64, uint8, int8, uint16, and int16
  • ksizes: list of ints with length ≥ 4
  • strides: list of ints, must be [1, stride_rows, stride_cols, 1]
  • rate: list of ints, must be [1, rate_rows, rate_cols, 1]
  • padding: string, either VALID or SAME. VALID indicates that the selected patch area must be completely included in the source image. SAME indicates that the part that exceeds the source image is padded with 0.
  • name: optional
[Constraint]
None
[Output]
No
47
tf.floormod
FloorMod
[Parameter]
  • name: optional
[Constraint]
[Output]
No
48
tf.nn.softmax
Softmax
[Parameter]
  • logits: non-null Tensor of type float32
  • axis: dimension softmax to be performed on, default to –1, indicating the last dimension. The value cannot be greater than the rank of logits.
  • name: optional
  • dim: (deprecated) equivalent to axis
[Constraint]
  • Softmax can be performed on each of the four input dimensions.
    According to axis:
    When axis = 1: C ≤ ((256 x 1024/4) – 8 x 1024 – 256)/2
    When axis = 0: n ≤ (56 x 1024 – 256)/2
    When axis = 2: W = 1, 0 < h < (1024 x 1024/32)
    When axis = 3: 0 < W < (1024 x 1024/32)
  • If the input contains fewer than four dimensions, softmax is performed only on the last dimension, with the last dimension ≤ 46,080.
[Output]
Tensor of the identical type and shape as logits
Yes
49
tf.math.pow
Power
[Parameter]
  • name: optional
[Constraint]
power! = 1
scale*x + shift > 0
[Output]
1 tensor
Yes
50
tf.placeholder
[Parameter]
  • dype: (mandatory) data type
  • shape: (mandatory) shape of the tensor to be fed
[Constraint]
None
[Output]
1 tensor
No
51
tf.shape
Shape
[Parameter]
  • input: Tensor or SparseTensor
  • out_type: data type for the output tensor, either int32 (default) or int64
[Constraint]
None
[Output]
Tensor of the data type specified by out_type
No
52
tf.math.argmax
ArgMax
[Parameter]
  • input: Tensor, must be one of the following types: int8, uint8, int16, uint16, int32, int64, float32
  • axis: 1 tensor of type: int32 or int64
  • out_type: data type for the output tensor, either int32 or int64 (default)
[Constraint]
None
[Output]
No
53
tf.gather
Gather
GatherV2
[Parameter]
  • params: 1 tensor, must be at least rank axis + 1
  • indices: tensor of type int32 or int64, must be in range [0, params.shape[axis])
  • axis: output tensor of type int32 or int64, specifying the axis in params to gather indices from, rank = 0
[Constraint]
None
[Output]
Tensor of the identical data type as params
No
54
tf.gather_nd
GatherNd
[Parameter]
  • indices: 1 tensor of type: int32 or int64
[Constraint]
  • indices: The last dimension of indices can be at most the rank of params.
  • The elements in the last dimension of indices correspond to the coordinates along a dimension of params. Therefore, the coordinate rules must be met.
  • The coordinates of the corresponding dimension in the indices cannot exceed the dimension size.
[Output]
Yes
55
tf.math.floordiv
FloorDiv
[Parameter]
  • y: Tensor, denominator of type float32 or int32
[Constraint]
[Output]
Tensor, floor (x/y)
No
56
tf.range
Range
[Parameter]
  • start: start constant scalar of type float32 or int32
  • limit: end constant scalar of type float32 or int32
  • delta: stride constant scalar of type float32 or int32
  • dtype: data type of the resulting tensor
[Constraint]
None
[Output]
1 1D tensor
No
57
tf.tile
Tile
[Parameter]
  • multiples: 1D constant tensor of type int32. The length must be the same as that of input.
[Constraint]
None
[Output]
1 tensor
Yes
58
tf.size
Size
[Parameter]
  • input: tensor of type float32
  • out_type: data type for the output tensor, default to int32
[Constraint]
None
[Output]
No
59
tf.fill
Fill
[Parameter]
  • dims: 1D tensor of type int32
  • value: variable of type int32 or float32
[Constraint]
The following padding modes are supported: Constant, GivenTensor, Range, Diagonal, Gaussian, MSRA, Uniform, UniformInt, UniqueUniform, and XavierFill. When the Uniform, UniformInt, UniqueUniform, and xavier padding modes are used, the value range of the generated value is [min, max).
[Output]
No
60
tf.concat
Concat
[Parameter]
  • value: list of tensor objects of type int32 or float32
  • axis: int32, indicating the dimensions to concatenate
[Constraint]
[Output]
1 tensor
Yes
61
tf.reverse
Reverse
[Parameter]
  • axis: int32, indicating the dimensions to reverse
[Constraint]
None
[Output]
No
62
tf. reduce_sum
sum
[Parameter]
  • input_tensor: tensor input
  • axis: int32, indicating the dimensions to sum up
  • reduction_indices: (deprecated) string, equivalent to axis
  • keep_dims: deprecated alias for keepdims
[Constraint]
None
[Output]
No
63
tf. math.maximum
Maximum
[Parameter]
  • max: tensor, must be one of the following types: int32, int64, float32
  • y: tensor of the identical data type as x
[Constraint]
[Output]
Tensor. Returns the max of x and y (x < y ? x:y)
Identical data type as x
No
64
tf. math.minimum
Minimum
[Parameter]
  • name: optional
[Constraint]
Broadcasting is supported in the following two scenarios:
NHWC + scaler, NHWC + NHWC
[Output]
No
65
tf.clip_by_value
ClipByValue
[Parameter]
  • t: Tensor
  • clip_value_min: minimum value to clip by
  • clip_value_max: maximum value to clip by
[Constraint]
The minimum value must be less than or equal to the maximum value.
[Output]
Clipped tensor. The return value range is [clip_value_min, clip_value_max].
No
66
tf.math.logical_not
LogicalNot
[Parameter]
  • x: tensor of type bool
[Constraint]
None
[Output]
Tensor of type bool
No
67
tf.math.logical_and
LogicalAnd
[Parameter]
  • y: tensor of type bool
[Constraint]
Broadcasting is supported in the following dimension scenarios: NHWC and [1,1,1,1], [N,H,W,C], [N,H,W,1], [1,H,W,C], [N,1,1,C]
[Output]
Tensor of type bool
No
68
tf.equal
Equal
[Parameter]
  • x: Tensor
[Constraint]
Broadcasting is supported, so shape of x and shape of y are compared. For a right-aligned dimension, the values of xdim[i] and ydim[i] are the same. If not, one of them must be 1 or missing.
[Output]
Tensor of type bool
No
69
tf.square
Square
[Parameter]
  • x: Tensor
[Constraint]
None
[Output]
No
70
tf.image.crop_and_resize
CropAndResize
[Parameter]
  • image: 4D tensor, must be one of the following types: float32, int8, int32, int64, with shape [num_boxes, 4]
  • boxes: 2D tensor of type float32, with shape [num_boxes]
  • box_ind: 1D tensor of type int32
  • crop_size: 1D 2-element tensor of type int32
  • method: string, indicating the interpolation method, either bilinear (default) or nearest
[Constraint]
None
[Output]
No
71
tf.math.top_k
TopKV2
[Parameter]
  • input: 1D tensor or higher with the last dimension at least k, of type float32 (k: scalar of type int32, ≥ 1)
  • sorted: bool
[Constraint]
k must be a constant.
[Output]
  • values: tensor, indicating k largest elements along each last dimensional slice
  • indices: tensor, indicating the indices of values of input
    No
72
tf.invert_permutation
InvertPermutation
[Parameter]
  • x: 1D tensor of type int32 or int64
[Constraint]
None
[Output]
No
73
tf.multinomial
Multinomial
[Parameter]
  • logits: 2D tensor, with shape [batch_size, num_classes]
  • num_samples: scalar, indicating the number of samples to draw
  • seed: int32 or int64, used to create a random seed
  • output_dtype: integer, data type for the output tensor, default to int64
[Constraint]
When seed is 0, the generated random is dynamic.
Number of rows in the output data = Number of rows in the output data; Number of columns in the output data = num_samples
[Output]
Tensor of the data type specified by output_dtype
No
74
tf.reverse_sequence
ReverseSequence
[Parameter]
  • input: tensor input
  • seq_lengths: 1D tensor of type int32 or int64
  • seq_axis: scalar of type integer
  • batch_axis: scalar of type integer
[Constraint]
  • The length of seq_lengths must be equal to the number of elements of input in batchAxis.
  • The maximum element in seq_lengths must be less than or equal to the number of elements in seq_dim.
  • seqAxis, batchAxis, seqDim, and batchDim must be of type int64.
  • seqAxis and seqDim are exclusive. batchAxis and batchDim are exclusive.
  • batchAxis and batchDim are optional. The default values are 0.
[Output]
Tensor of the data type specified by input
No
75
tf.math.reciprocal
Reciprocal
[Parameter]
[Constraint]
The input data cannot contain 0.
[Output]
No
76
tf.nn.selu
Selu
[Parameter]
[Constraint]
None
[Output]
No
77
tf.math.acosh
Acosh
[Parameter]
[Constraint]
None
[Output]
No
78
tf.math.asinh
Asinh
[Parameter]
[Constraint]
None
[Output]
No
79
tf.math.reduce_prod
Prod
[Parameter]
  • axis: dimension to reduce
[Constraint]
None
[Output]
Tensor and reduced tensor
No
80
tf.math.sqrt
Sqrt
[Parameter]
[Constraint]
None
[Output]
No
81
tf.math.reduce_all
All
[Parameter]
  • input_tensor: tensor of type bool
  • keepdims: bool
[Constraint]
None
[Output]
No
82
tf.nn.l2_normalize
L2Normalize
[Parameter]
  • x: Tensor of type boolean
  • axis: dimension along which to normalize
    • For format NCHW, axis must be set to 1.
    • For format NHWC, axis must be set to 3.
  • epsilon: lower bound value for the norm. If norm < sqrt(epsilon), sqrt(epsilon) is used as the divisor.
[Constraint]
H*W*2 < 256*1024/4
[Output]
No
83
tf.keras.backend.hard_sigmoid
Hardsigmoid
[Parameter]
x: tensor input
[Constraint]
None
[Output]
Output Tensor. If x < –2.5, 0 is returned. If x > 2.5, 1 is returned.
If -2.5 ≤ x ≤ 2.5, 0.2 * x + 0.5 is returned.
No
84
tf.keras.layers.ThresholdedReLU
ThresholdedReLU
[Parameter]
theta: scalar of type float32, ≥ 0
[Constraint]
None
[Output]
Tensor
No
85
tf.math.acos
Acos
[Parameter]
x: Tensor of type float32, int32, or int64
[Constraint]
The input data range is (–1 ≤ x ≤ 1), and the output data range is (0 ≤ y ≤ π).
[Output]
No
86
tf.math.atan
Arctan
[Parameter]
[Constraint]
The input data range is (-65504 ≤ x ≤ 65504), and the output data range is (-π/2 ≤ y ≤ π/2).
[Output]
No
87
tf.math.asin
Asin
[Parameter]
  • x: Tensor of type float32, int32, or int64
[Constraint]
The input data range is (–1 ≤ x ≤ 1), and the output data range is (-π/2 ≤ y ≤ π/2).
[Output]
No
88
tf.math.atanh
Atanh
[Parameter]
[Constraint]
Input data range: x within (-1, 1)
[Output]
No
89
tf.math.tan
Tan
[Parameter]
[Constraint]
None
[Output]
No
90
tf.math.logical_or
LogicalOr
[Parameter]
  • y: Tensor of type bool
[Constraint]
[Output]
Tensor of type bool
No
91
tf.math.reduce_min
ReduceMin
[Parameter]
  • input_tensor: Tensor, must be one of the following types: float32, int64, int32, uint8, uint16, int8, int16
  • keepdims: scalar of type bool
[Constraint]
[Output]
No
92
tf.math.negative
Neg
[Parameter]
  • x: Tensor of type float32, int64, or int32
[Constraint]
The input data range is (-65504 ≤ x ≤ 65504), and the output data range is (-65504 ≤ y ≤ 65504).
[Output]
Tensor. Returns –x.
No
93
tf.math.greater_equal
Greaterequal
[Parameter]
  • x: Tensor, must be one of the following types: float32, int64, int32, uint8, uint16, int8, int16
[Constraint]
[Output]
Tensor of type bool
No
94
tf.space_to_depth
SpaceToDepth
[Parameter]
  • input: tensor, must be one of the following types: float32, int64, int32, uint8, int8
  • block_size: scalar of type integer, ≥ 2
  • data_format: string, must be NHWC (default), NCHW, or NCHW_VECT_C
[Constraint]
blockSize ≥ 1 and blockSize must be a divisor of both the input height and width.
[Output]
No
95
tf.depth_to_space
DepthToSpace
[Parameter]
[Constraint]
blockSize ≥ 1, and blockSize * blockSize must be exactly divided by C.
[Output]
No
96
tf.math.round
Round
[Parameter]
[Constraint]
None
[Output]
Tensor of the identical data type and shape as x
No
97
tf.math.rint
Rint
[Parameter]
  • x: tensor, must be one of the following types: float32, int64, int32, uint8, int8
[Constraint]
None
[Output]
No
98
tf.math.less
Less
[Parameter]
[Constraint]
None
[Output]
Tensor of type bool
No
99
tf.math.sinh
Sinh
[Parameter]
[Constraint]
None
[Output]
Tensor of the identical output type as x
No
100
tf.math.cosh
Cosh
[Parameter]
[Constraint]
None
[Output]
No
101
tf.math.squared_difference
Squared_difference
[Parameter]
[Constraint]
Broadcasting is supported only in the following scenarios:
One NCHW tensor and one tensor of the following format: dim{} = [1,1,1,1], [N,C,H,W], [N,1,H,W], [1,C,H,W], [N,C,1,1], [1,C,1,1], [1,1,H,W], or [N,1,1,1]
[Output]
No
