Viewing Device Logs
After running a HiLens skill, you can view the device agent logs and skill logs.
Query Methods
- Viewing Logs Using SSH: Connect to the HiLens Kit device using SSH and view the logs.
 - Managing Data: On the Data Management (Beta) page of the Huawei HiLens console, you can download and view skill running logs of each device.
- Connect to a HiLens Kit device using SSH. For details, see Connecting a HiLens Kit Device to a PC.
 - Run corresponding commands to view logs based on the firmware version.
- Firmware versions earlier than 1.0.4 (excluding 1.0.4):
 - Firmware 1.0.4 to 1.1.1:
 - Firmware 1.1.2 or later:
     To ensure that your device can run newer and better skills, you are advised to upgrade its firmware in a timely manner. For details about how to upgrade the firmware, see Upgrading HiLens_Device_Agent Firmware.
