- What's New
- Function Overview
- Getting Started
User Guide
- Who Uses HiLens
- Procedures for Using HiLens
- Permissions Management
- Creating a Workspace
- Registering HiLens Kit Devices
- Managing Devices
- Developing Skills on the Console
- Using the Skill Market
- Managing Data
- Managing Products
- Caffe Operator Boundaries
- TensorFlow Operator Boundaries
- Best Practices
Developer Guide
- Before You Start
- HiLens Framework Introduction
- Initialization
- Video Input Module
- Audio Input Module
- Preprocessing Module
- Model Management Module
- Output Module
- EIServices Module
- Resource Management Module
Hard Example Upload Module
- Introduction to Hard Example Upload
- Initializing
- Determining a Hard Example Image in a Detection Algorithm
- Determining a Hard Example Image in a Classification Algorithm
- Uploading a Hard Example Image Set
- Obtaining Hard Example Configurations
- Updating Hard Example Configurations
- Example - Hard Example Upload
- Log Module
- Error Codes
- Change History
- SDK Reference
HiLens Kit Devices
Device Introduction
- What Are the Differences Between HiLens Kit and Atlas 500?
- What Are the Differences Between HiLens Kit and Atlas 200 DK?
- What Is HiLens Kit?
- What Is the Focal Length of a HiLens Kit Camera? Can It be Adjusted?
- What Cameras Can Be Connected to HiLens Kit?
- Can I Develop HiLens Kit Skills Using Compute Architecture for Neural Networks (CANN)?
Device Hardware Operations
- What Storage Devices Can Be Mounted to the USB Port of a HiLens Kit Device?
- What Does the Red Indicator of a HiLens Kit Device Mean?
- How Do I Restore HiLens Kit Devices to Factory Settings?
- Can HiLens Kit Connect to Multiple USB Cameras?
- Do I Need to Use Other Devices Together with HiLens Kit Devices?
- How Do I Quickly Switch a HiLens Kit Device to the Wireless Network Configuration Mode?
- Does HiLens Kit Support Infrared Interfaces?
Device System Operations
- How Do I Log In to a Device Using SSH?
- After I Change the Password for a Huawei HiLens Device, Why Can't I Use PuTTY to Log In to the Device Even Though I Can Use the New Password to Log in to Huawei HiLens IES?
- How Do I Perform Bottom-Layer Operations on the HiLens Kit System?
- Can I Import a Custom Python Module to a HiLens Kit Device?
- How Do I Install YUM on HiLens Kit Devices?
- How Do I Manage Device Files?
- How Do I Install Software Packages on HiLens Kit Devices?
- How Do I Log In to a Device as Root User and Disable Connection Timeout?
- Can Python-based OpenMV Devices Invoke HiLens Kit Skills by Calling APIs?
- Why a HiLens Kit Device Cannot Display Chinese Characters?
- How Do I Clear Wi-Fi Information Saved on a HiLens Kit Device?
- How Do I Use SSH Commands to Connect a HiLens Kit Device to a Wi-Fi Network?
- How Do I Configure Permanent DNS on a HiLens Kit Device?
Device Introduction
Device Registration
- How Do I Handle Device Registration Failures with Different Causes Returned?
- How Do I Check Whether a Huawei Cloud Account Is Bound to a Device?
- What Should I Do If I Can't Access the Huawei HiLens IES?
- What Should I Do If There Is Not Enough Quota for Device Registration?
- Why Do HiLens Kit Devices Fail to Connect to Wi-Fi?
- How Do I View the IP address of a Wireless Network?
- What Do I Do If the System Displays a Message Indicating that Only Firmware 1.0.3 or Later Can Be Registered When I Use Register a Device with the Intelligent Edge System?
- What Are the Differences Between Using IES and SSH to Register a HiLens Kit Device?
- What Do I Do If I Forgot the Password to the Huawei HiLens Intelligent Edge System?
Managing Devices
- What Should I Do If the Device Is Offline for More Than 5 Minutes After a Firmware Upgrade?
- Do I Need to Upgrade Firmware in Sequence?
- Why Does the Firmware Upgrade Fail When the Device Is Online?
- What Should I Do If the System Displays a Message Indicating That the Upgraded Version Must Be Later Than the Current Version During Firmware Upgrade?
- What Can I Do If a Device Alarm Is Reported Indicating That the Directory Space Is Full?
Skill Development
- What Are the Causes of Skill Creation Failures?
- What Models Does Huawei HiLens Support?
- How Do I Upload Models to Huawei HiLens?
- Can One Skill Use Multiple Models? How Do I Add Multiple Models When Developing a Skill?
- Why Does Skill Releasing Fail?
- Can Sockets Be Used During Skill Development?
- How Do I Handle a Model Conversion Failure?
- To What Devices Does the HiLens Framework SDK Apply?
- How Do I Determine the Input Tensor Shape During Model Conversion?
- Does Huawei HiLens Only Support Models Trained by ModelArts?
- Can Skills Developed on Huawei HiLens Be Deployed on Edge Servers That Use P4 GPUs?
Installing and Starting Skills
- What Are the Possible Causes for Skill Installation Failures?
- How Many Skills Can Run on a HiLens Kit Device Concurrently?
- Why Does a Skill Stop After Being Started?
- Can a HiLens Kit Device Run Skills Offline?
- What Can I Do If Skill A Is Successfully Started But Skill B Fails to Be Started When the Two Skills Purchased from the Skill Market Are Both Output by HDMI?
- Purchasing Skills
- Managing Products
Managing Data
- Why Is There No HDMI Skill Data on the Data Management Page?
- How Do I Configure the Data Storage Location (OBS Storage Path)?
- Why Does HDMI Black Screen Occur or HDMI Output Stop Working?
- Can I Record the Images Captured by a HiLens Kit Camera or the Skill Running Result for Storage?
- Why Don't the Logs Contain Any Device Data?
Algorithm Issues
- Why Is Error Code 17 Displayed During Model Inference?
- How Do I Use and Program the SDK or License of a Skill?
- Can a Huawei HiLens Skill Run on an Android or Arm Platform?
- What TensorFlow and Caffe Models Can Run on Huawei HiLens?
- Does Huawei HiLens Support Self-Developed Operators?
- What Language Does the Huawei HiLens Development Environment Support?
- Does HiLens Kit Provide an Interface that Converts a Color Image to a Grayscale Image?
- How Do I Configure Python Dependencies for a Skill?
Other
- Why Does the Huawei HiLens Console Keep Reporting 404 Errors?
- How Do I Assign Huawei HiLens Permissions to New IAM Users?
- Does Huawei HiLens Support 3D Object Recognition?
- What Can I Do If the System Displays a Message Indicating that the AK/SK Pair Is Unusable?
- What Devices Does Huawei HiLens Support?
HiLens Kit Devices
Subscribing to Skill Messages
After you subscribe to messages for a specified skill, the subscription object (recipient) will receive an email or SMS notification when the skill has any output.
For example, assume that a skill has the function of detecting strangers and sending messages, that is, the skill's Product Description on the skill details page contains "This skill supports notification messages". Then, after you install the skill and subscribe to a message topic (Configuring Subscription Objects), the configured subscription object will receive an email or SMS notification when the device detects a stranger.
Precautions
- When subscribing to a message for the first time, restart the skill so that the subscription object can receive the message. For details about how to restart the skill, see Starting or Stopping Skills.
- The skill supports the message notification function. This function is configured during skill development. For details about the guide and APIs, see the HiLens Developer Guide.
If the message notification function is not configured for a skill, common users cannot receive notification messages from the skill.
- The skill has been deployed on a device and is in the Running state. Users cannot receive notification messages from a skill not in the Running state.
A subscription object is the recipient of notification messages. When the device detects a specified scenario (for example, a stranger detection skill installed on the device detects a stranger), the subscription object can receive a notification message.
- Log in to the Huawei HiLens console, choose Device Management > Devices in the navigation pane. The device list page is displayed.
- Click the card of the device where the skill is installed. The Skill Management page is displayed by default.
Figure 1 Accessing the device details page
- Click the name of the skill for which you want to configure a subscription object. The skill details page is displayed.
- Click the Skill Messages tab.
Figure 2 Skill message
- Set the Current Skill Topic.
- To add a new topic:
- Click
on the right of Existing Topics. In the text box that is displayed, enter a topic name, which contains a maximum of 255 characters, starting with a letter or digit. Only letters, digits, underscores (_), and hyphens (-) are allowed. Then, click
- Click
on the right of the topic. In the dialog box that is displayed, click OK to confirm the skill topic setting.
- Click
- To add an existing topic:
Click
on the right of an existing topic. In the dialog box that is displayed, click OK to confirm the skill topic setting.
- Click Back to Skill Messages in the upper right corner of the Skill Messages tab to configure the message recipient of the current skill topic.
Figure 3 Back to Skill Messages
- Click
on the right of the subscription list. The Message Management dialog box is displayed.
Figure 4 Message recipients - Edit the message recipients of the current topic as follows:
- To add a new recipient:
Click Add Message Recipient and enter recipient information in the text boxes that are displayed. For details about the parameters, see Table 1. Confirm the information and click
- To edit an existing recipient:
Click
on the right of a message recipient and re-enter the recipient information in the text boxes. For details about the parameters, see Table 1. Confirm the information and click
You can click Set to Default to set the default recipient for quick subscription. (You can click
on the right of the subscription list in step 4 to perform quick subscription.)
- Click to select the recipient who subscribes to the skill, and click OK.
The subscription list is displayed. You can view the added recipient.
To add multiple message recipients, go to step 7.
Figure 5 Subscription list - After the message recipient is added, the recipient will receive a text message or email. Click Confirm Subscription.
The subscription is successful if you receive a feedback indicating successful subscription.
After the recipient confirms the subscription, you need to restart the skill, so that the recipient will receive an email or SMS notification when the skill has any output.
In the subscription list, the recipient icon changes from gray to orange
