Modifying a Bandwidth
If an EIP has been bound to a FlexusX instance, the instance can access the Internet using the bandwidth specified for the EIP. You can modify the name, billing mode, and size of a bandwidth. This section describes how to modify the bandwidth of a FlexusX instance.
The rule for modifying an EIP bandwidth depends on the billing mode of the EIP.
EIP Billing Mode |
Billing Mode Changeable |
Bandwidth Change |
Billing Description |
Yearly/Monthly |
No |
Pay-per-use |
Yes |
You can increase or decrease the bandwidth. The changes are applied immediately. |
Pay-per-use billing is a postpaid mode, so after the bandwidth is modified, you will be billed based on the new billing mode. |
- The yearly/monthly and pay-per-use billing modes in Table 1 define how an EIP is billed, not how the FlexusX instance is billed.
Yearly/Monthly EIPs can only be billed by bandwidth, but pay-per-use EIPs can be billed by bandwidth, traffic, or shared bandwidth.
- When you purchase a yearly/monthly FlexusX instance, if you select Traffic or Shared bandwidth for Billed By, the EIP is billed on a pay-per-use basis. In this case, use the rules for modifying the bandwidth of a pay-per-use EIP.
- You can only modify bandwidth for FlexusX instances with EIPs bound.
- If a yearly/monthly EIP is bound to a FlexusX instance:
- Only the bandwidth name and bandwidth size can be modified. A yearly/monthly EIP can only be billed by bandwidth.
- The bandwidth size can be increased in the current subscription period, and decreased for the renewal period.
- Only the bandwidths of pay-per-use EIPs billed by bandwidth or traffic can be modified in batches. The bandwidths of yearly/monthly EIPs or pay-per-use EIPs billed by shared bandwidth cannot be modified in batches.
- Log in to the FlexusX console, in the upper left corner, click , and select a region and project.
- Locate the FlexusX instance you want to modify the bandwidth for. Modify the bandwidth in either of the following ways:
- In the Operation column of the FlexusX instance, choose More > Manage Network > Modify Bandwidth.
- If the EIP bound to the FlexusX instance is billed by bandwidth or traffic, select the instance, and on the top of the list, choose More > Modify Bandwidth. You can use this method to modify bandwidth for such instances in batches.
- Follow the instructions to modify the bandwidth.
- Click Next: Confirm, confirm the information, and click Submit.
