Help Center/ Huawei Cloud Flexus/ User Guide/ FlexusL/ Managing Backups/ Viewing Backup Information and Supported Operations
Updated on 2024-06-18 GMT+08:00
Background
Cloud Backup and Recovery (CBR) enables you to back up cloud servers and disks with ease. In case of a virus attack, accidental deletion, or software or hardware fault, you can restore data to any point in the past when the data was backed up.
CBR involves backups, vaults, and policies.
  • A backup is a copy of a particular chunk of data and is usually stored elsewhere so that it may be used to restore the original data in the event of a data loss.
  • CBR stores backups in vaults. If your server contains the cloud backup service, the cloud servers or disks will be associated with the corresponding vault, and cloud server backups or cloud disk backups generated will be stored in the associated vault.
  • There are backup policies and replication policies.
    • Backup policies: To perform automatic backups, configure a backup policy by setting the execution times of backup tasks, the backup cycle, and retention rules, and then apply the policy to a vault.
    • Replication policies: To automatically replicate backups or vaults, configure a replication policy by setting the execution times of replication tasks, the replication cycle, and retention rules, and then apply the policy to a vault. Replicas of backups must be stored in replication vaults.
For more information, see What Is CBR?
  1. Log in to the FlexusL console and click a resource card to go to the instance details page.
  2. In the list on the left, choose Cloud Backup Vaults. View the vault information and supported operations in the package on the right.
    Details
    Disk Name/ID
    Name and ID of the EVS disk, which cannot be changed
    You can click to copy the disk ID.
    Vault Status
    A vault can be in any of the following states:
    : The vault is available.
    : The vault expires.
    : The vault is abnormal.
    Backup Type
    Backup type of a cloud server is server backup, which backs up all EVS disks (system and data disks) on the server.
    Backup Policy Status
    Whether the backup policy is enabled. The policy is enabled by default after you create the cloud server.
    When you enable a backup policy, you can click the policy name to view the policy details.
    Associated Server
    Server that has been associated with the vault
    Used/Total Vault Capacity
    Used capacity and total capacity of the vault, in GB. The vault capacity usage is also displayed.
    Operation
    • Modifying an applied policy: Click to modify the backup policy. For details, see Modifying a Policy.
    • Viewing monitoring data: Click to view backup monitoring data.
