Help Center/ Huawei Cloud EulerOS/ User Guide/ Tools/ Security Hardening Tools
Updated on 2024-09-14 GMT+08:00
Overview
HCE 2.0 is a Linux distribution for Huawei Cloud users. By default, security hardening is not performed after the ISO is installed.
security-tool is a Huawei-developed security hardening tool package that meets Huawei's basic security hardening requirements. By default, security-tool is not installed with HCE 2.0. You can install security-tool as required. After security-tool is installed, automatic security hardening is performed when the OS is started for the first time. You can also harden your OS by referring to the Huawei Cloud EulerOS 2.0 Security Configuration Baseline if needed.
For details about security hardening, see the security-tool RPM package. The security hardening items are as follows:
  • System services: for example, configuring SSH, deleting postfix.service, and enabling haveged.service
  • Kernel parameters: for example, kernel network protocol stack
  • Accounts and passwords: for example, PAM parameters
  • Authorization and authentication: for example, warning banner and umask
  • File permissions: for example, cron configuration
Using security-tool
  1. Install the security-tool package.
    If the package exists in the repository, run the yum command to install it.
    yum install -y security-tool
    If no, obtain the security-tool package from the repository on the Huawei Cloud official website.
  2. Specify the type of the configuration to be hardened in the /etc/hce_security/hce_enhance_type.conf file.
    There are three types of configurations: cybersecurity (graded protection hardening), hwsecurity (cloud service hardening), and general (general hardening). general is recommended. general is used as an example in the following steps.
    echo general > /etc/hce_security/hce_enhance_type.conf
  3. Start the hce-security service.
    systemctl start hce-security
    Run the systemctl status hce-security command to check the service status. If the status is active(exited), the security hardening is successful.
    For details about security hardening logs, see /var/log/hce_security.log.
    You can modify the /etc/hce_security/usr-security.conf file to configure security hardening items. The method of modifying the configuration file is as follows:
    # HowTo:
    #       # delete key, and difference caused by blankspace/tab on key is ignored
    #       id@d@file@key
    #       # modify option: find line started with key, and get the value changed
    #       id@m@file@key[@value]
    #       # modify sub-option: find line started with key, and then change the value of key2 to value2(prepostive separator should not be blank characters) in the line
    #       id@M@file@key@key2[@value2]
    #       # check existence of commands
    #       id@which@command1 [command2 ...]
    #       # execute command on the files found
    #       id@find@dir@condition@command
    #       # any command(with or without parameter), such as 'rm -f','chmod 700','which','touch', used to extend functions, return 0 is ok
    #       id@command@file1 [file2 ...]
    # Notes:
    #       1. The comment line should start with '#'
    #       2. "value" related with "key" should contain prepositive separator("="," " and so on), if there is any.
    #       3. When item starts with "d", "m" or "M", "file" should be a single normal file, otherwise multi-objects(separated by blankspace) are allowed.
    If you want to harden the security for more items, refer to Huawei Cloud EulerOS 2.0 Security Configuration Baseline or other Huawei Cloud OS security hardening specifications.
Enabling SELinux affects system performance. SELinux is disabled in HCE by default. To enable SELinux, you need to restart the OS for multiple times. SELinux cannot be enabled in one click. For details about how to enable SELinux, see How Do I Enable SELinux on an ECS Running HCE?
Differences Between general, hwsecurity, and cybersecurity
Check Item Type
Check Item
Check Content
general
hwsecurity
cybersecurity
Satisfied by Default
Initial configuration
File system configuration
Partition key system directories for mounting.
No
Ensure that unnecessary file systems are disabled.
No
Ensure that partitions that do not need to be modified are mounted as read-only.
No
Ensure that partitions that do not need to be mounted with devices are mounted in nodev mode.
No
Ensure that partitions without executable files are mounted in noexec mode.
No
Ensure that partitions that do not require SUID/SGID are mounted in nosuid mode.
No
Avoid using USB storage.
Yes
Software service configuration
Forbid the installation of the X Window System (X11, or simply X).
Yes
Disable the debug-shell service.
Yes
Disable the rsync service.
Yes
Disable the avahi service.
Yes
Disable the SNMP service.
Yes
Disable the squid service.
Yes
Avoid enabling the samba service.
Yes
Disable the FTP service.
Yes
Disable the TFTP service.
Yes
Disable the DNS service.
Yes
Disable the NFS service.
Yes
Disable the rpcbind service.
No
Disable the LDAP service.
Yes
Disable the DHCP service.
Yes
Do not install the CUPS software.
Yes
Do not install the NIS software.
Yes
Do not install the Telnet software.
Yes
Do not install the NIS client.
Yes
Do not install the LDAP client.
Yes
Do not install debugging tools.
Yes
Do not install development and compilation tools.
Yes
Do not install network sniffing tools.
Yes
Software upgrade configuration
Ensure that the GNU Privacy Guard (GPG) public key is configured.
Yes
Ensure that gpgcheck is enabled.
Yes
Ensure that the software repository source is configured.
Yes
File integrity check
Ensure that the Advanced Intrusion Detection Environment (AIDE) is installed.
No
Set periodic file integrity check.
No
Common process hardening
Ensure that address space layout randomization (ASLR) is enabled.
Yes
Ensure that core dumps are correctly configured.
Yes
Restrict the number of files that can be opened by users.
No
Ensure that link file protection is correctly configured.
Yes
Ensure that the dmesg access permission is correctly configured.
No
Ensure that access to the kernel symbol address is restricted.
Yes
Restrict the ptrace for processes.
No
Do not set the global encryption policy to LEGACY.
Yes
System services
Time synchronization service
Configure the ntpd service correctly.
No
Configure the chronyd service correctly.
Yes
Cron service
Ensure that the cron service is running normally.
Yes
Ensure that the cron configuration permission is correct.
No
Secure Shell (SSH) service
Ensure that the /etc/ssh/sshd_config permission is correctly configured.
Yes
Ensure that the permission on the SSH private key file is correctly configured.
No
Ensure that the permission on the SSH public key file is correctly configured.
No
Ensure that IgnoreRhosts is enabled.
Yes
Configure the authentication blacklist and whitelist correctly.
No
Ensure that Privileged Access Management (PAM) authentication is enabled for SSH.
Yes
Forbid login as user root.
No
Forbid login using an empty password.
Yes
Forbid host-based authentication.
Yes
Ensure that the warning banner file path is configured.
No
Ensure that the SSH log level is correctly configured.
Yes
Configure the listening IP address of the SSH service.
No
Configure an appropriate number of concurrent unauthenticated SSH connections.
No
Forbid X11 forwarding.
No
Set the value of SSH MaxSessions less than or equal to 10.
Yes
Ensure that MaxAuthTries is correctly configured.
No
Forbid PermitUserEnvironment.
Yes
Set the value of LoginGraceTime less than or equal to 60 seconds.
No
Ensure that the idle timeout is configured.
No
Forbid AllowTcpForwarding.
No
Ensure that strong SSH key exchange algorithms (KexAlgorithms) are configured.
Yes
Ensure that strong SSH message authentication codes (MACs) are configured.
Yes
Ensure that strong SSH Ciphers are configured.
Yes
Do not configure the options that will be discarded by SSH.
Yes
Network services
Unused network protocols and devices
Avoid using uncommon network services.
No
Avoid using WLANs.
Yes
Network protocol stack in the kernel space
Disable the system from responding to ICMP broadcast packets.
Yes
Do not receive ICMP redirect messages.
No
Do not forward ICMP redirect messages.
Yes
Ignore all ICMP requests.
No
Ensure that forged ICMP packets are ignored.
Yes
Ensure that reverse address filtering is enabled.
No
Disable IP forwarding.
Yes
Disable the option of receiving source route packets.
No
Ensure that TCP-SYN cookie protection is enabled.
Yes
Enable logging to record suspicious network packets.
No
Do not enable tcp_timestamps.
No
Ensure that TIME_WAIT for TCP is configured.
Yes
Ensure that the number of queues in the SYN_RECV state is correctly configured
No
Do not use the ARP proxy.
Yes
Firewall configuration
firewalld
Enable the firewalld service.
Yes
Ensure that iptables is not enabled.
Yes
Ensure that nftables is not enabled.
Yes
Configure valid default zones.
No
Ensure that the network interfaces are bound to the correct zones.
No
Avoid enabling unnecessary services and ports.
No
iptables
Enable the iptables service.
No
No
Yes
Configure the default rejection policy.
No
Configure the iptables loopback policy.
No
Configure the iptables INPUT policy.
No
Configure the iptables OUTPUT policy.
No
Configure association policies for the iptables INPUT and OUTPUT.
No
nftables
Enable the nftables service.
No
Yes
No
No
Configure the nftables loopback policy.
No
Configure the nftables INPUT policy.
No
Configure the nftables OUTPUT policy.
No
Configure association policies for the nftables INPUT and OUTPUT.
No
Log auditing
auditd
Ensure that auditd is enabled.
Yes
Ensure that auditd can be enabled when the system boots.
No
Ensure that audit_backlog_limit is correctly configured.
No
Ensure that the maximum size of a single log file is specified.
Yes
Ensuring that ROTATE is enabled for audit logs.
No
Ensure that audit logs are not automatically deleted.
Yes
Ensure that disk space thresholds are correctly configured.
Yes
Avoid setting a small rate limit threshold for audit logs.
Yes
Configure the sudoers audit rule.
No
Configure a login audit rule.
Yes
Configure a session audit rule.
Yes
Configure an audit rule for time change.
No
Configure an SELinux audit rule.
No
Configure an audit rule for the network environment.
No
Configure an audit rule for file access control permissions.
No
Configure an audit rule for file access failures.
No
Configure an audit rule for file deletions.
No
Configure an audit rule for account information modifications.
No
Configure an audit rule for file system mounting.
No
Configure the audit rule for privilege escalation commands.
No
Ensure that the audit rule for kernel module changes.
Yes
Configure an audit rule for sudo log file modifications.
No
rsyslog
Ensure that the rsyslog service is enabled.
No
Ensure that system authentication-related events are recorded.
Yes
Ensure that cron logs are recorded.
Yes
Configure the log records of each service correctly.
Yes
Configure the default rsyslog file permission correctly.
No
Configure a rotation policy for rsyslog.
No
Configure the option of sending logs to a remote log server.
No
Ensure that remote rsyslog messages are received only on the specified log host.
No
Ensure that the option of dumping journald logs of the rsyslog service has been configured.
No
Account and password management
Account management
Forbid login capabilities for accounts that are not used for login.
No
Forbid unused accounts.
No
Set the account validity period correctly.
No
Forbid non-root accounts with UID 0.
Yes
Ensure that the UIDs are unique.
Yes
Ensure that the GIDs are unique.
Yes
Ensure that the account names are unique.
Yes
Ensure that the group names are unique.
Yes
Ensure that all groups exist in /etc/passwd.
Yes
Ensure that an account has its own home directory.
Yes
Ensure that the permissions on the home directory of the account are 750 or stricter.
Yes
Avoid the .forward file in the home directory.
Yes
Avoid the .netrc file in the home directory.
Yes
Ensure that the user PATH variable is strictly defined.
Yes
Password management
Ensure the password complexity.
No
Restrict the number of reusing a historical password.
No
Ensure that passwords do not contain the account character strings.
Yes
Ensure that passwords are encrypted using SHA512.
No
Ensure that the password expiration time is correctly configured.
No
Ensure that the password expiration alarm time is correctly configured.
Yes
Ensure that the password change period is correctly configured.
No
Ensure that inactive passwords are locked for no more than 30 days.
Yes
Ensure that the password protection is configured for GRUB.
Yes
Ensure that password protection is configured in the single-user mode.
Yes
Identity authentication
Login management
Lock an account after a specific number of login failures.
No
Prevent user root from accessing the system locally.
No
Ensure that the timeout duration of sessions is correctly configured.
No
Warning banners
Ensure that the local login warning banner contains proper information.
No
Ensure that the remote login warning banner contains proper information.
No
Ensure that the motd file contains proper information.
No
Ensure that the /etc/issue permission is correctly configured.
Yes
Ensure that the /etc/issue.net permission is correctly configured.
Yes
Ensure that the /etc/motd permission is correctly configured.
Yes
Access control
SELinux
Ensure that the enforce mode is enabled.
Yes
Ensure that the SELinux policy is correctly configured.
Yes
Avoid the services with the unconfined_service_t label.
No
Ensure that the SETroubleShoot service is not installed.
Yes
Ensure that the Mount Conversion Service (MCS) is not installed.
Yes
Privileged commands
Ensure that the su command is restricted.
No
Ensure that the su command inherits the user's environment variables without escalating privileges.
No
Ensure that common users run privileged programs using sudo.
No
Ensure that the sudo log file is configured.
No
Disable the SysRq key.
No
System file permissions
Ensure that the /etc/passwd permission is correctly configured.
Yes
Ensure that the /etc/passwd- permission is correctly configured.
Yes
Ensure that the /etc/shadow permission is correctly configured.
Yes
Ensure that the /etc/shadow- permission is correctly configured.
Yes
Ensure that the /etc/group permission is correctly configured.
Yes
Ensure that the /etc/group- permission is correctly configured.
Yes
Ensure that the /etc/gshadow permission is correctly configured.
Yes
Ensure that the /etc/gshadow- permission is correctly configured.
Yes
Ensure that the sticky bit is set for world-writable directories.
Yes
Forbid files or directories without owners or owning groups.
Yes
Avoid using world-writable files.
Yes
Forbid files with invalid links.
Yes
Forbid executable hidden files.
Yes
Ensure that unnecessary SUID or SGID bits in the file are deleted.
Yes
Ensure that umask is 027 or stricter.
No
  • The symbol √ indicates that the item is executed.
  • The symbol - indicates that the item is not executed.
