Solution Practices
Huawei Cloud solution practices and best practices of each product are collected on HaydnCSF for quick search. You can choose Solution Acceleration Field > Solution Practices to query a solution.
![](https://support.huaweicloud.com/intl/en-us/usermanual-haydncsf/public_sys-resources/note_3.0-en-us.png)
The sample code or architecture template included in a solution will also be released to the solution acceleration field.
Querying a Solution
On the Solution Practices page, you can query a solution using keywords, applicable industry, and applicable scenario. The following information can be obtained: solution name, applicable industry, applicable scenario with description, solution architecture description and advantages, and full text.
![](https://support.huaweicloud.com/intl/en-us/usermanual-haydncsf/en-us_image_0000001503735257.png)
Releasing a Solution
- On the Solution Practices page, click Release Solution Practices.
- On the displayed page, configure parameters as prompted.
Table 1 Parameters required for releasing a solution Parameter
Solution Attachment
(Mandatory) You can upload only one attachment with a size of not exceeding 50 MB. The attachment must be in .docx format and its name contains a maximum of 64 characters. Ensure that the attachment does not contain non-public information assets (including but not limited to key source code, faulty code, and full set of product or platform source code), unauthorized software or tools, and RMS-encrypted files.
Link to Official Website
Link to a solution on the Huawei Cloud official website. Generally, Huawei Cloud solution practices and best practices of each cloud service are linked.
Practice Name
Name of the solution.
Enterprise Name
Name of the authenticated enterprise that the current account belongs to, which is automatically displayed.
Applicable Industries
Industries that a solution applies to. You can select up to 10 industries.
Applicable Scenarios
Scenarios that a solution applies to. You can select up to 10 scenarios. Note: After entering a scenario name, click + to add the scenario.
Applicable Scenario Description
Describe the applicable scenario.
Solution Architecture
(Optional) Solution architecture of a solution. You can upload only JPG or PNG diagrams with the size of not exceeding 10 MB, and describe the solution architecture. You can upload multiple groups of solution architectures.
Solution Advantages
Advantages of the solution.
- Click Save to save the solution draft, and click Submit to submit the solution.
- Wait for the HaydnCSF operations administrator to approve the application. You can view the release status of the solution in My Release History.
