Updated on 2025-08-14 GMT+08:00
Creating a Graph Data Source
You have obtained the type, CIDR block, IP address, port, database name, and authentication information of the data source.
- Log in to the GES management console. In the navigation pane on the left, choose Data Migration.
- On the displayed Data Sources tab, click Create.
Figure 1 Creating a data source
- On the displayed page, set the parameters as follows:
- Data Source Name: Enter a name. The value must contain 4 to 50 characters and start with a letter. Only letters (case-insensitivity), numbers, and underscores (_) are allowed.
- Data Source Type: Select a type. The options are MySQL, ShenTong database, Oracle, GaussDB(DWS), and Hive.
- Graph Name: Select the graph where you want to import data.
- CIDR Block: CIDR block of the subnet where the data source is.
- Access IP Address: IP address of the database of the data source.
- Access Port: port number of the data source database (not involved in Hive).
- Database Name: Name of the database of the data source.
- Database Username: Username for logging in to the database of the data source (unavailable for Hive).
- Database Password: Password for logging in to the database of the data source (unavailable for Hive).
- Require Verification: Check if Kerberos authentication is enabled for the MRS cluster where Hive is (only available for Hive).
- MRS Cluster Username: Username of the MRS cluster where Hive is (only available for Hive). This parameter is optional when Kerberos authentication is disabled.
- MRS Cluster User Authentication Credential: Authentication credential of the user of the MRS cluster where Hive is (only available for Hive). This parameter is optional when Kerberos authentication is disabled.
- MRS Cluster Hive Client File: Hive client file (only available for Hive).
Click OK.
Figure 2 Data source information - Check the data source status and wait until the creation is complete.
Parent topic: Graph Data Migration
