Updated on 2025-09-10 GMT+08:00
GES Resources
A resource is an object that exists within a service. On GES, you can select these resources by specifying their paths.
Table 1 GES resources and their paths
Resource
Resource Name
Path
graphName
GES graph name
[Format]
GES:*:*:graphName:GES graph name
[Description]
For graph instance resources, GES automatically generates the prefix (GES:*:*:graphName:) of the resource path.
For the path of a specific graph instance, add the GES graph name to the end. You can also use an asterisk * to indicate any graph instance. Example:
GES:*:*:graphName:* indicates any GES graph instance.
backupName
GES backup name
[Format]
GES:*:*:backupName:GES backup name
[Description]
For graph instance resources, GES automatically generates the prefix (GES:*:*:backupName:) of the resource path.
For the path of a specific graph instance, add the GES backup name to the end. You can also use an asterisk * to indicate any backup graph instance. Example:
GES:*:*:backupName:* indicates any GES backup graph instance.
