Link Prediction
Overview
This algorithm is used to calculate the similarity between two nodes and predict their relationship based on the Jaccard measurement method.
This algorithm applies to scenarios such as friend recommendation and relationship prediction in social networks.
Parameter Description
| Parameter | Mandatory | Description | Type | Value Range | Default Value |
| source | Yes | Enter the source ID. | String | - | - |
| target | Yes | Enter the target ID. | String | - | - |
Example
Set parameters source to Lee and target to Alice to calculate the association between two nodes. The JSON result is displayed in the query result area.
