Louvain
Overview
Louvain is a modularity-based community detection algorithm with high efficiency and effect. It detects hierarchical community structures and aims to maximize the modularity of the entire community network.
Application Scenarios
This algorithm applies to scenarios such as community mining and hierarchical clustering.
Parameter Description
Parameter |
Mandatory |
Description |
Type |
Value Range |
Default Value |
convergence |
No |
Convergence |
Double |
A real number between 0 and 1 (excluding 0 and 1) |
0.00001 |
max_iterations |
No |
Maximum iterations |
Integer |
1–2000 |
100 |
weight |
No |
Weight of an edge |
String |
Empty or null string
The weight of an edge must be greater than 0. |
Null |
Precautions
This algorithm generates only the final community result and does not save the hierarchical results.
Example
Set parameters coverage to 0.00001 and max_iterations to 100, the sub-graphs of different communities are displayed on the canvas. The color of a node varies with communities. The JSON result is displayed in the query result area.
