Label Propagation
Overview
The Label Propagation algorithm is a graph-based semi-supervised learning method. Its basic principle is to predict the label information about unlabeled nodes using that of the labeled nodes. This algorithm can create graphs based on the relationships between samples. Nodes include labeled data and unlabeled data, and the edge indicates the similarity between two nodes. Node labels are transferred to other nodes based on the similarity. Labeled data is like a source used to label unlabeled data. The greater the node similarity is, the easier the label propagation will be.
Application Scenarios
This algorithm applies to scenarios such as information propagation, advertisement recommendation, and community discovery.
Parameter Description
Parameter |
Mandatory |
Description |
Type |
Value Range |
Default Value |
convergence |
No |
Convergence |
Double |
A real number between 0 and 1 (excluding 0 and 1) |
0.00001 |
max_iterations |
No |
Maximum iterations |
Integer |
1–2000 |
1000 |
initial |
No |
Name of the property used as the initialization label on a vertex |
String |
Null or string
If the value of initial is not null, the number of vertices with initialization labels must be greater than 0 and less than the total number of vertices. |
Precautions
Label Propagation uses IDs as labels by default.
Example
Set parameters coverage to 0.00001 and max_iterations to 1,000, the sub-graphs with different labels are displayed on the canvas. The color of a node varies with labels. The JSON result is displayed in the query result area.
