Updated on 2023-08-04 GMT+08:00
Shortest Path
Overview
The Shortest Path algorithm is used to find the shortest path between two nodes in a graph.
Application Scenarios
This algorithm applies to scenarios such as path design and network planning.
Parameter Description
Table 1 Shortest Paths algorithm parameters
Mandatory
Type
Value Range
Default Value
source
Yes
Enter the source ID of a path.
String
target
Yes
Enter the target ID of a path.
String
directed
No
Whether an edge is directed
Bool
true or false
false
weight
No
Weight of an edge
String
Empty or null character string
  • Empty: The default weight and distance are 1.
  • Character string: The attribute of the corresponding edge is the weight. When the edge does not have corresponding attribute, the weight is 1 by default.
    The weight of an edge must be greater than 0.
timeWindow
No
Time window used for time filtering
Json
For details, see Table 2.
timeWindow does not support the shortest path with weight. That is, parameters timeWindow and weight cannot be both specified.
Table 2 timeWindow parameters
Mandatory
Type
Value Range
Default Value
filterName
Yes
Name of the time attribute used for time filtering
String
Character string: The attribute on the corresponding vertex/edge is used as the time.
filterType
No
Filtering by vertex or edge
String
V: Filtering by vertex
E: Filtering by edge
BOTH: Filtering by vertex and edge
BOTH
startTime
No
Start time
String
Date character string or timestamp
endTime
No
End time
String
Precautions
This algorithm only returns one shortest path.
Example
Calculate the shortest path from the Lee node to the Alice node.
Set parameters source to Lee, target to Alice, weight to weights, and directed to false. The shortest path is displayed on the canvas, and the JSON result is displayed in the result area.
