Updated on 2025-07-22 GMT+08:00
K-hop
Overview
K-hop is an algorithm used to search all nodes in the k layer that are associated with the source node through breadth-first search (BFS). The found sub-graph is the source node's ego-net. The K-hop algorithm returns the number of nodes in the ego-net.
Application Scenarios
This algorithm applies to scenarios such as relationship discovery, influence prediction, and friend recommendation.
Parameter Description
Table 1 K-hop algorithm parameters
Mandatory
Type
Value Range
Default Value
k
Yes
Number of hops
Integer
(0-10]
source
Yes
Node ID
String
mode
No
Direction:
  • OUT: Hop from the outgoing edges.
  • IN: Hop from the incoming edges.
  • All: Hop from edges in both directions.
String
OUT, IN, ALL
OUT
Precautions
  • A larger k value indicates a wider node coverage area.
  • According to the six degrees of separation theory, all people in social networks will be covered after six hops.
  • BFS searches information based on edges.
Example
Select the algorithm in the algorithm area of the graph engine editor. For details, see Analyzing Graphs Using Algorithms.
Calculate the sub-graph formed by the three hops starting from the Lee node.
Set parameters k to 3, source to Lee, and mode to OUT. The sub-graph is displayed on the canvas, and the JSON result is displayed in the query result area.
