K-core
Overview
K-core is a classic graph algorithm used to calculate the number of cores of each node. The calculation result is one of the most commonly used reference values for determining the importance of a node so that the propagation capability of the node can be better understood.
Application Scenarios
This algorithm applies to scenarios such as community discovery and finance risk control.
Parameter Description
| Parameter | Mandatory | Description | Type | Value Range | Default Value |
| k | Yes | Number of cores The algorithm returns nodes whose number of cores is greater than or equal to k. | Integer | Greater than or equal to 0 | - |
Precautions
None
Example
Set parameter k to 10. The sub-graph formed by nodes whose number of cores is greater than or equal to 10 in the calculation result is displayed on the canvas. The color of a node varies with the number of cores. The JSON result is displayed in the query result area.
