PageRank
Overview
PageRank, also known as web page ranking, is a hyperlink analysis algorithm used to rank web pages (nodes) based on their search engine results. PageRank is a way of measuring the relevance and importance of web pages (nodes).
- If a web page is linked to many other web pages, the web page is of great importance. That is, the PageRank value is relatively high.
- If a web page with a high PageRank value is linked to another web page, the PageRank value of the linked web page increases accordingly.
Application Scenarios
This algorithm applies to scenarios such as web page sorting and key role discovery in social networking.
Parameter Description
| Parameter | Mandatory | Description | Type | Value Range | Default Value |
| alpha | No | Weight coefficient (also called damping coefficient) | Double | A real number between 0 and 1 | 0.85 |
| convergence | No | Convergence | Double | A real number between 0 and 1 | 0.00001 |
| max_iterations | No | Maximum iterations | Integer | 1–2000 | 1000 |
| directed | No | Whether an edge is directed | Boolean | true or false | true |
   - alpha determines the jump probability coefficient, also called damping coefficient, which is a computing control variable in the algorithm.
- convergence indicates the upper limit of the sum of each absolute vertex change between an iteration and the last iteration. If the sum is less than the value of this parameter, the computing is considered converged and the algorithm stops.
Precautions
When the convergence is set to a large value, the iteration will stop quickly.
Example
Select the algorithm in the algorithm area of the graph engine editor. For details, see Analyzing Graphs Using Algorithms.
Set parameters alpha to 0.85, coverage to 0.00001, max_iterations to 1,000, and directed to true. The sub-graph formed by top nodes in the calculation result is displayed on the canvas. The size of a node varies with the PageRank values. The JSON result is displayed in the query result area.
