Updated on 2025-08-14 GMT+08:00
Accessing the Graph Editor
You can use the graph editor to query and analyze graphs. It has extensive built-in algorithms for customers to use in different scenarios of different fields. In addition, it is compatible with the Gremlin and Cypher query languages and supports open APIs. GES is easy to use even for zero-based users.
The procedure is as follows:
  1. Log in to the GES management console and choose Graph Management from the navigation pane on the left.
  2. On the Graph Management page, select the graph to be accessed and click Access in the Operation column.
    Figure 1 shows the graph editor page. You can analyze the graph data on the graph editor. For details, see Graph Editor.
    Figure 1 Graph editor
