Help Center/
Graph Engine Service/
User Guide/
Managing Created Graphs/
Backing Up and Restoring Graphs/
Deleting Backup Graph Data
Updated on 2025-07-22 GMT+08:00
If backup data is no longer used, you can delete it as needed.
The procedure is as follows:
- Log in to the GES management console and choose Backup Management from the navigation pane on the left.
- In the backup list, select your desired backup and click Delete in the Operation column.
- In the dialog box that appears, enter DELETE (or click Auto Enter) and click Yes.
- Deleted data cannot be recovered. Exercise caution when performing this operation.
- You cannot delete the automatic backup data of a graph that has not been deleted.
Parent topic: Backing Up and Restoring Graphs
