GES Overview
Graph Engine Service (GES) is a service for querying and analyzing graph structure data based on relationships. It is particularly well suited for scenarios requiring analysis of rich relationships, such as social relationship analysis, marketing recommendations, social listening, information communication, and anti-fraud.
This document describes how to perform operations and analyze graph data on the GES management console.
The figure below shows usage process.
| Step | Description | Reference |
| Make preparations | Before using GES, create a Huawei Cloud Account and complete real-name authentication. | |
| Grant GES permissions to a user group and add a user to that group. | ||
| Import a metadata file | Local import: Import metadata files to GES for subsequent graph creation. | |
| Import from OBS: Upload the prepared metadata file to an OBS bucket in advance for subsequent import into GES. | ||
| Create a graph | Create a graph using various methods. | |
| Incrementally import data | After creating a graph, you can import data into the graph. You can also incrementally import graph data. | |
| Access the graph editor | Introduces the areas of the graph editor. | |
| Analyze a graph using the graph editor | Analyze and query graphs using the graph editor. | |
| Manage metadata | Copy, edit, search for, and delete created metadata. | |
| Manage created graphs | Manage created graphs and check graph information. | |
| Configure graph permissions | Set fine-grained permissions at the label and property levels for managed graphs and grant permissions to user groups. | |
| Check graph instance tasks | On the overview page, viewing My Resources helps you quickly understand overall information and billing details of existing graphs. | |
| In the task center, you can check details about asynchronous tasks, such as creating, backing up, starting, and deleting graphs. |
